jmr
You got that right oil is cheap and engines are not. I change it every 5K with 5W-30 synthetic oil the lifters and camshaft will thank you.
Did mine at 2,320 miles. Out of curiosity after reading about others having issues with filter replacement on the 4x4 5.7L combo.So here's a different question... When should you do your FIRST oil change?
He doesn't only work on race engines. I only stated that part, to show his experience, that he has worked with engines his entire life, starting with his famous Nascar racing father. He also has videos about changing the oil in his daughter's Toyota. I am a former master certified mechanic, and before seeing his videos, I used to go by the computer, because it takes into account, things like load, and temperature. The only thing the computer can't take into account, is dirt in the air. After watching the guy with the degree in lubrication, explaining everything, my opinion changed. The factory only worries about the engine lasting as long as the warranty.I’ll watch some of his videos… anyone can learn from anyone.
Point being…to be clear. You parroted all his ideas…and based it on race engines, to tell me I basically wasn’t worthy and didn’t know as much as someone else, while placing all your faith in knowledge in someone else.
I find it amusing that you mentioned Amsoil in the city department squad vehicles.. Amsoil is one of the biggest snake oil out there, both by their sales marketing and dealer distro model.
So the factory computer can take into account everything except dirt in the air.He doesn't only work on race engines. I only stated that part, to show his experience, that he has worked with engines his entire life, starting with his famous Nascar racing father. He also has videos about changing the oil in his daughter's Toyota. I am a former master certified mechanic, and before seeing his videos, I used to go by the computer, because it takes into account, things like load, and temperature. The only thing the computer can't take into account, is dirt in the air. After watching the guy with the degree in lubrication, explaining everything, my opinion changed. The factory only worries about the engine lasting as long as the warranty.
My 2019 manual and cap say 5w20. I believe it was changed in 2021.Just did my 1st @1022mi. on my 23 5.7. Installed fumoto valve, Mopar filter, Mobil 1 5w20.
When reinstalling the oil fill cap I noticed it says 0w20. Owners manual also says use 0w20.
Currently debating on whether or not I should do it again with 0w20.
Opinions anyone?
I would... in 5,000 milesJust did my 1st @1022mi. on my 23 5.7. Installed fumoto valve, Mopar filter, Mobil 1 5w20.
Opinions anyone?
Your motor is now destroyed. Never gonna run again.Just did my 1st @1022mi. on my 23 5.7. Installed fumoto valve, Mopar filter, Mobil 1 5w20.
Opinions anyone?
Opinions anyone?
Every 3000 - 5000 miles with Rotella T6 5W-40 and Motorcraft FL-1A filters.
Steve
I go every 5,000 it's a 2021 and only have 8.716 on it,I've always changed the oil and filter in my year 2000 Golf TDI every 6 months (approx 5000miles) , always using the correct VW spec oil and OEM filters. Recently I read a couple of threads where folks stated that changing the oil so frequently was unnecessary and that the interval could be pushed to 8000 miles without any additional engine related wear.
So am I overdoing the oil changes and therefore spending money for no good reason? or should I stick with my regime in the knowledge that my engine should last past 100K?
So, I just towed a 6k lb trailer, 2-5 hours trips back to back, I'm getting ready for a big trip, about 16 hours of towing over 2 days. Should I change the oil before the trip? 5.7 hemi, e torque, 2022 25k miles. Thoughts?From what I’ve read, the roller lifter needle bearing “needles” in the 5.7 Hemi were increased in size to improve the needle bearing failure problem starting in the 2017 model year.
My 2011 Hemi Ram had lifter needle bearing failure at 180K in mid 2021. Over 60% of those miles were towing a 7k# enclosed car hauler. I religiously changed oil at 3k miles using 5w20 semi-synthetic oil and filter.
My 2022 Hemi Ram is getting oil changes at 5k miles now with MS-6395 0w20 full synthetic oil (whatever is on sale) and I can do these for $40 with a Mopar M0-339 filter.
For me, I believe changing oil more often at 40- 45% oil life left will produce excellent results for my type of usage.
