silver billet
- Apr 18, 2019
Not how it works? I've read plenty of engineering reports that thinner oil gets to places thicker oil doesn't as well, you can't say they all get there equally at the same time can you? They all get there eventually, but there is a reason for different weights and thickness right? They flow better at temperature when thinner. Good reason why my E90 went from 60W to 50W recommendation due to the already tight bearing tolerances leading to excessive wear. The thicker oil took longer to lubricate the bearings, especially when cold, when lubrication is most critical.
Again, you haven't answered my first question in two replies regarding the 6.4L using 40W oil and still getting lifter failure. That it can't be thinner oil being the cause for the lifter failures on 5.7L if the 6.4L uses thicker oil and still has the same lifter issues. Can you respond to that?
I've answered both your statements already. Thicker oil doesn't take any longer to reach lifters than thinner oil. It's not about getting to places, it's about film strength. These hemis use postive displacement oil pumps, the oil is getting pumped no matter how thick it is, unless your oil is so thick (past 75-ish psi, can't remember exactly) at which point the oil pump goes into safety bypass.
Keep in mind that the "0w" part of the oil is what matters when talking about cold temps. A 0w-20 is just as pumpable in the cold temps as a 0w-40, that's the entire reason for the winter grade.
As for the 40w, again already answered as best anyone can. We know that 40w offers more protection than 20w (this is a basic fact of tribology), we don't know for sure how viscosity affects lifter failures as it relates to hemi tick, but we do know that in general your engine (including lifters) is better protected using 30 or 40 weight oils.
