silver billet
- Apr 18, 2019
Can you show us exactly where the Blackstone report states the oil should have been changed sooner to prevent lifter failure?
Or where the oil has sufficient life left to service the rest of the motor, but… changing it sooner would prevent or stall lifter failure?
My point.. one has nothing do with the other.
This forum doesn't allow links to the other forum which has discussed this in nauseating detail. The information is there if you google it.
Blackstone can't tell you the state of carbon/varnish buildup, which is one theory as to what is taking out the lifters. Keeping your oil clean is the first step in keeping those needle bearings free from crud.
I use a high efficiency filter, and also run HPL which is exceptional at cleaning, as well as having massive amounts of friction and anti-wear ingredients. I also run 0w-30 or 5w-30.
None of this will guarantee you don't get lifter failure, but it will help your chances.
Many guys have run Redline and successfully heard their tick disappear either partly or completely. Again the details are on the other forum.
I generally don't get into these discussions anymore since they just degenerate into nothing very quickly. There is no straight line from Ram saying "you need to do X to prevent Y". But the information is out there if you want it, and if your mind is already made up that $30/qt oil is the same as $100/qt oil then no amount of evidence will be sufficient to change your mind, so why bother talking about it? It really makes no difference to me what you guys do, my truck gets the best treatment and chances it can possibly get.
