Nice. Except for Ramboxes your truck is a twin of mine.
How good does it tow with that setupMy new Lance 2445 bunkhouse travel trailer. Overall length a smidge under 30 feet. 5500 lbs. dry, 7600 lbs. GVWR. And looks like it was designed to be towed by a white Limited.
Nice, level towing setup too with the air suspension and Andersen WDH.View attachment 58466View attachment 58467
If set up correctly it seems to tow well. The Andersen hitch is a little different than other WDHs. The chain tension seems to make a world of difference. Last time I pulled out of the campground I don’t think I had the tension right and the front of the truck felt a little light. After I stopped and tightened the chain on one side it improved a lot. I haven’t really towed before this setup so I don’t have a solid frame of reference. But I did drive a 24’ Class C motorhome a few months prior to this and found that to be more affected by cross winds than my 30’ trailer. So maybe the sway control of the Andersen is making a difference.How good does it tow with that setup
From what I understand, the class IV hitch rating is 1150lbs/14,000lbs. I'll never comment negative on anyone's gear, but I seen some TTs that scares me to see them being pulled by a ram 1500 class IV.
I would like to know the failing point of that hitch, i imagine that the rating is far below it but still, I would love to know.
I feel when at 1,000lbs TT tongue, plus the WD bars, the tow hitch itself and other accessories, your easily at or over 1150lbs.
I’ll take a look when I go out to the truck next. What’s your experience with the Andersen? I’ve now towed around 1000 miles with it. But these were very long trips so I only hitched up a few times. I don’t think I have it dialed in. Truck feels like it gets pushed around too much in the wind. And if I don’t tighten it until the socket bottoms out I get the truck’s stability control kicking in sometimes. Granted, this is mostly towing in the desert with strong, gusty winds. But I also wasn’t going over 65mph. On the other hand, I don’t feel any change in handling when I go over bumps in the road, so the hitch must be doing something right. Thoughts?Interesting that your setup is nearly identical to mine (other than trailer brand). Even the Anderson WDH that I kept when I sold my 2009 Ram. I'm curious what the payload rating shows on the yellow sticker. By VIN, my is listed at 1090lbs, quite a bit lower than I expected. Since our builds are nearly identical, I'd be interested in what your payload rating is.
Mine is 1129lbs. My guess is that your multi-function tailgate is the primary difference... I have just a normal one.Interesting that your setup is nearly identical to mine (other than trailer brand). Even the Anderson WDH that I kept when I sold my 2009 Ram. I'm curious what the payload rating shows on the yellow sticker. By VIN, my is listed at 1090lbs, quite a bit lower than I expected. Since our builds are nearly identical, I'd be interested in what your payload rating is.
Thanks. That's helpful. I meant that I was driving 65 or less, not 65 mph wind speed. Just estimating from flags, I think the wind speed was probably 15-20-ish, gusting from there.I know you asked for dougs thoughts but I’ll throw mine in as I use the Andersen and tow TTs for the Mfgrs to their dealerships nationwide with the 4th gen Ram ED. Plenty of which go through windy Wyoming & New Mexico.
65 mph gusts mean you should probably stop & take a brake no matter your truck & hitch. But max stability is found at the CAT scale as in my above post. Level truck especially with air suspension can be deceiving and does not mean in itself that your axle weighs & tongue weight are well set up. That’s proven on the CAT triple scale that weighs all three sets of axles at the same time to see what the eye & or even measurements cannot.
I'm still fairly new to the Anderson as well. I only used it twice for ~100 miles trips last fall. My trips were on winding roads through the mountains and not much wind so I can't provide any feedback. I thought it did great for my scenario, but with the new truck I will be traveling across I80 in Wyoming and I90 in Montana. Both experience high winds at times in some areas, so I guess I'll find out. I plan to take a long trip in August and will try to remember to come back and provide some feedback on how it went.I’ll take a look when I go out to the truck next. What’s your experience with the Andersen? I’ve now towed around 1000 miles with it. But these were very long trips so I only hitched up a few times. I don’t think I have it dialed in. Truck feels like it gets pushed around too much in the wind. And if I don’t tighten it until the socket bottoms out I get the truck’s stability control kicking in sometimes. Granted, this is mostly towing in the desert with strong, gusty winds. But I also wasn’t going over 65mph. On the other hand, I don’t feel any change in handling when I go over bumps in the road, so the hitch must be doing something right. Thoughts?
If you have the VIN, and you looked it up by the VIN, then it is accurate. The MFT is a bit heavier than the traditional tailgate.I'm still fairly new to the Anderson as well. I only used it twice for ~100 miles trips last fall. My trips were on winding roads through the mountains and not much wind so I can't provide any feedback. I thought it did great for my scenario, but with the new truck I will be traveling across I80 in Wyoming and I90 in Montana. Both experience high winds at times in some areas, so I guess I'll find out. I plan to take a long trip in August and will try to remember to come back and provide some feedback on how it went.
However, I may not take delivery of the truck (due 6/29) if the payload on the yellow sticker matches the 1009lb VIN lookup payload. I need at least 200lb more to feel comfortable. The dealership thinks the VIN lookup on the online Ram towing-guide is wrong. I guess we'll see. The only difference I can see between your rig and the one I ordered is that I ordered mine with the multifunction tailgate .. but that may be the problem if Ram beefs up the bed to support the 'barn door' setup.
Did you set up the hitch yourself? I'm curious if you followed the instructions RAM owners manual of how to set up a WDH hitch with trucks that have air suspension (standard on the Limited?) It requires a specific process that instructs you to put the air suspension in tire jack mode when doing the setup. If done correctly, you will not tighten the WDH all the way until the hitch is level. There is a formula that is used, allowing the air suspension to self level to the final leveled height.Thanks. That's helpful. I meant that I was driving 65 or less, not 65 mph wind speed. Just estimating from flags, I think the wind speed was probably 15-20-ish, gusting from there.
I do need to get this rig onto a scale. I was running with a bike rack on the back. Dry the trailer has only 10% tongue weight per spec, so 550 lbs. Total weight of rack and 2 bikes was a good 100lbs, and cantilevered out past the rear bumper. I wasn't carrying much water or other gear over the front of the trailer. So that could have lightened the tongue weight a bit.
Andersen customer support tells me I can tighten it up to a 1/4 inch compression of the red bushings. I haven't done that, mine looks like below. But I do have it pretty well wrenched down. When I left the dealer a little over a month ago they only had 3-4 threads showing.
You question wasn't addressed to me, but I've been using the Andersen WDH so I'll chime in. I pull a 32' travel trailer that weighs about 7500 lbs loaded.What’s your experience with the Andersen? I’ve now towed around 1000 miles with it. But these were very long trips so I only hitched up a few times. I don’t think I have it dialed in. Truck feels like it gets pushed around too much in the wind. And if I don’t tighten it until the socket bottoms out I get the truck’s stability control kicking in sometimes. Granted, this is mostly towing in the desert with strong, gusty winds. But I also wasn’t going over 65mph. On the other hand, I don’t feel any change in handling when I go over bumps in the road, so the hitch must be doing something right. Thoughts?
