Buz
- Sep 18, 2020
So I did locate the quick connect plug next to the sub last night and disconnected it while I had some 'boomy' music playing. The moment I disconnected the plug it was like the fog lifted and the sun came out. This was with Pandora via USB wired source. I am now able to get the bass setting on the EQ into positive territory.
I've only had about 15 minutes total listening time since then, but here are my initial observations:
-Surprisingly, the door speakers put out a decent amount of bass. You would never know this with the sub hooked up since the bass setting was always down in the -6 area, so no real bass was ever getting to the door speakers. More midrange is noticeable now too.
-Unfortunately the doors vibrate a lot now with volume at 30+ and moderate bass on the EQ. I'm concerned things will loosen up over time and rattle.
-With a decent wired source (Pandora, Spotify, etc) plugged into Uconnect the sound has become cleaner, punchier and more balanced, which is a definite improvement.
-The true, low deep bass is gone, which I do notice, but the elimination of the 'boomyness' is the better tradeoff here.
-Satellite radio still sounds like crap, probably even more so now without the sub since less bass is present in an already 'tin can' sounding medium.
-FM radio I haven't tested much but sounded a bit thin without the sub.
-I find I'm fiddling with the EQ more now depending on the volume and style of music. Now that bass is actually available at more levels, I'm tweaking it a lot more to get the music 'in focus'. A 'loudness' button would probably help in this case since I'm mostly punching up the bass & treble when I lower the volume now that the sub is gone.
-Surround Sound is hit or miss now. With the sub connected I almost always preferred surround ON. Now I find that turning it off sometimes makes it sound better.
-I've moved the fader from center (when sub was attached) to two clicks toward the front. It's a better soundstage now than it was with the sub for sure.
So overall I'm happier with the cleaner, punchier sound, but still feel quite disappointed that my premium HK system in my super expensive truck is hobbled without good low frequency enhancement. It's a workaround for a botched OEM sound system, which sucks.
Also, I'm hoping the amp is smart enough to know the sub is disconnected. I'm concerned that even though the sub circuit is now open, that the amp may still be amplifying that channel and storing it as heat inside the amp, which will kill it over time.
