Honestly I think that's just because it's away from the white numbering which would dilute the blue. Numbering is evenly lit though. Anyone like that I wouldn't think twice about.
Mine just started inconsistent illumination of gauge cluster. 2547 miles. The speedometer 40,60,80 speed is bright, the rest of the numbers are dim. Tachometer 2,4,6 bright, rest are dim. In parade mode all illuminate but the described problem above you can see they are a trace lighter.
I wanted to provide an update, that FCA sent a tech advisor and she did a lot testing last week (I was out of town on business). She supplied the results to RAM engineers and they have already replied on Tuesday. I am taking the truck in on Monday, and they will install a known GOOD cluster on Tuesday. The engineers are actually programming at the factory with my mileage, etc. and sending it overnight. If you kept up with the thread then you know the dealer stated they already replaced the cluster when I first reported the issue. I am optimistic they simply have a supplier issue and this is a good cluster, otherwise there is something else going on.
Glad you finally got some satisfaction.Alright fellow forum members, a new cluster was installed and I now have even lighting. I will say that it appears not as bright but it's so hard to tell anymore so I compared it with another Limited they just got in and it appears to be the same. If you folks with hot spots think it's normal then you are wrong but if it doesn't bother you then it doesn't matter.
It is done one purpose and it’s normalAnymore news on this topic? I have the same thing, the speeding and rpm gauge lighting is uneven. It almost looks as if it's done on purpose though
