Neurobit
RAM Sorcerer
Took a picture of a Limited with eTorque this afternoon that I test drove. View attachment 1933
Yep, mine looks like this (everything lit up). So it seems dealer doesn't know jack.
Yours is not normal, the first picture shows uneven lighting and that is not how it's supposed to be.
Well that looks pretty normal to me. If that is what you guys are concerned about, then I gotta say that I don’t think it’s an issue.
Cheers,
Neurobit.
Ok thanks, without your headlights on this switch seems to do nothing, which is interesting because there is some ambient light sensor somewhere because I have seen the gauges be different levels of brightness without the headlights on.
I got my cluster replaced today (it went dark on day 1). It took the dealer a whole week just to get the part in, only an hour to replace it but another 19 showed up there today with the same issue . Not sure if mine is related to the bright spots issue but something aggravating none the less.
Both of my gauges definitely have uneven lighting. Not sure if it's worth messing with though.
The rep came and took a lot of measurements, checked grounding etc. They had 3 Limiteds on the lot which all looked perfect so the rep knows something isn't right. So all you folks who think it's normal or don't care should be caring and report it. I'll keep posted when I find out more. I'm glad my dealer is helping and FCA is too. I hope they find a solution. My opinion is they have a batch of bad clusters but we'll see...
Glad to hear it's moving in the right direction. Definitely keep us updated. I found this photo I took of when I had a Limited for the night and it's definitely evenly lit so for the ones that aren't its definitely not normal.
