kapinallinen2
- Jan 16, 2019
- Location
- Southern Maryland.
The factory solder joint had failed on this replacement window that was done under warranty.Really, I mean @hskr rt has a point. I permatexed the window because of all the leaks reported for years , and waterproofed the RH. now is this next?
I repaired it with conductive silver epoxy, then started thinking about uneven temperature distribution possibly causing the window to shatter.
Ended up disconnecting the connection for a piece of mind.
