Exploding back sliding glass / defroster overheating
Tennessee
Back sliding window exploded this morning as I was pulling out of my driveway. I remote started the truck about 4mins before heading out this morning. Temp was around 33 degrees. Smelled smoke when entering the truck, but had a neighbor behind us that lost a tree a few weeks ago and thought he may have started a burn pile. Drove to end of drive and then boom. It looks like the contacts on the sliding glass window super heated the glass and melted a hole in the rubber weather stripping. Does anyone know if just the slider can me replaced or is a whole new rear window required?
Damn, that sucks, not sure if they sell just the slider glass due to it being electric sliding with connection to a motor.
Geddyflea
Like HSKR R/T said, I'm not sure either. The black rubber connector broke off of mine and the dealer replaced the entire back window.
Biggiehorn
Saint Cloud, FL
That's pretty scary. I've come across multiple posts both on here and across other platforms where the owner's claim that their rear glass just randomly shattered, but haven't seen anything like that yet. Can't answer your question on the replacement portion either, but I would certainly want to have all of that electrical thoroughly inspected in addition to replacing the glass.
6of36
Michigan
I have never heard of a rear defogger itself ever overheating. More than likely, there was a loose connection that arced, and that could cause extreme heat. Also in my experience, even before they were power, The entire window needs replacing. ( I think that glass is put in while assembling the frame, so is only able to be installed or removed with the frame out of the vehicle.)
Tennessee
Got the whole rear glass replaced today. I had a 03 that the slider got broken by a guy loading my truck with lumber , so I expected the same on the 5th Gen. The flag decal was on the outside. Had OEM glass put into it. Ins covered 2/3s. Contacts must have arched to one another causing the glass to super heat. The sensor was detached when I got the truck and I bought some electronic welding solder. I guess after a season of use it must have liquified (dripped) and caused the issue. Word to the wise, don’t try that fix if you have the same detachment issue.
Lawman1Bravo
2021 Ram 1500 Limited . Well mine just did . I remote started it . Temp outside is in the mid 30’s the rear defrost was on and as my wife was putting groceries in the back she seen smoke coming from the back seat and a few seconds later the small back window shattered . So yes it does happen and it’s B. S. only 15,000 miles on it .
