Exploding back sliding glass / defroster overheating
Really, I mean @hskr rt has a point. I permatexed the window because of all the leaks reported for years , and waterproofed the RH. now is this next?
The factory solder joint had failed on this replacement window that was done under warranty.
I repaired it with conductive silver epoxy, then started thinking about uneven temperature distribution possibly causing the window to shatter.
Ended up disconnecting the connection for a piece of mind.
where did you disconnect, I could not see it. Found fuse #47 but wondering what else like maybe mirrors won t defrost . I really don t need the rear defroster down in the south. But I like the auto start sometimes. Also when I pulled 47 the icon button still lite up? Should have know the I had the rear seat out once. Plus is it not permenatly connected? Thanks.
Disconnected the one on the drivers side. You can get to it without taking anything apart.
The F47 is dedicated to the rear defrost so that will disable it also without effecting anything else.
The button light gets it input from the BCM AFAIK.
Has there been any recall on this in Canada? Mine just broke, hubby comes in after work asked if I was aware my back passenger side rear window was busted? I damn near had a heart attack thinking someone tried to steal it..but he says no it's blown out ward, no sign of break in. So for the sake of peace of mind I thought I'd check if it's an issue..and obviously it is... roughly a grand and a week until I can get it fixed.Merry Christmas to me!
What happened with this, did you go through the dealer? I had the same thing happen to me but I was in the vehicle as it exploded. Dealer didn't want to look at it thoroughly and since ive opened an investigation. Please let me know what happened in your case as i'm trying to figure out what my best option is here
We're sorry to hear of this! Please send our team a detailed private message for an extra layer of support alongside the dealer.
Diamond
Ram Cares
