Exhaust Manifold Leak
My 2019 had the ticking until warm that started at about 40K miles. I brought it in about 2 weeks ago at 43K and they found bolts sheared off at cylinders 7 and 8. Manifold was intact and they replaced 8 bolts. No more ticking.
Cylinder Head Material: Aluminum
Cylinder Block Material: Cast-iron
I assume the 5.7 exhaust manifolds are cast iron?
Aftermarket headers are either cast iron or machined stainless steel correct?
I wonder if they added a thick steel spacer plate it would stiffen the manifolds so the problem would go away? Maybe not enough room between the fenders or firewall?
In all my years of vehicles owned, I never ran into header problems. This is my first 5.7 Hemi.
I had the same problem on a 2004 F150. It is not too unusual. Aluminum and Iron have different coefficients of expansion.
Well I’ve grown tired of the startup exhaust leak and I started removing my headers (PITA BTW). Confirmed that the header is cracked about an inch at the back cylinder, drivers side. You can see the light coming through. You can also see the ceramic coating that is flaking off like burnt paint. Why do Ram Hemi’s hate exhaust manifolds so much?! :p0CB12F43-043D-4989-9C6C-4FD90804CEF4.jpeg3564E369-81B9-4056-ABC4-6894535C3C70.jpeg
well this morning I noticed the exhaust leak, looked at the passenger side manifold and the manifold bolt head has snapped off. Dropped off at dealership. Hope powertrain warranty will cover it at 52k . @RamCares
That would be good to know if I ever have the issue
Is it necessary to wrap the shorty headers? I am looking at getting the AFE headers and would like to avoid wrapping them unless it is absolutely required or will cause some kind of issue.
Well I’ve grown tired of the startup exhaust leak and I started removing my headers (PITA BTW). Confirmed that the header is cracked about an inch at the back cylinder, drivers side. You can see the light coming through. You can also see the ceramic coating that is flaking off like burnt paint. Why do Ram Hemi’s hate exhaust manifolds so much?! :pView attachment 129430View attachment 129431
Were those eBay headers? I’ve seen better welds in my high school shop class. No wonder they cracked.
They were covered on my 4th gen under the powertrain warranty at 55k when a couple studs sheared off. Heres to hoping 🤞
I personally would not wrap them. Ceramic coating can help with heat issues, and not hold water encouraging rust like wrap.
Might as well have been. AFE, direct purchase from Mfg. I’m not impressed either. Must have been made on a “bring your kid to work” day. I’m not a professional welder but I wouldn’t be showing people my welds if they looked like that.
Don't laugh too hard at just AFE. I've had Hooker headers around year 2000 that had to be totally rewelded also, as well as removing a golfball size wad of cold weld inside the collector. 🤪
At my second manufacturing job, one of our high class salesman came out to nag at the welding supervisor. He was complaining that he was showing a customer a prototype of a weldment, and he was secretly embarrassed at the crap welds. This salesman had more input than the supervisor on the wage of welders in this small co'. Weld supervisor says, "You pay $15/hr, you get a $15/hr weld". "Enlightenment" was had, so they simply lowered their targeted customer quality level. 🤣
Add another to the ever growing list. 2019 with 29k miles. Both exhaust manifolds are cracked. Dealer told me it could be up to 6 months until they get them. Very disappointed this is happening with such frequency on these trucks.
Business neighbor is an industrial fabrication shop. They are making the repair to the manifold since I can’t wait for AFE to play the warranty game.
Shop manager said that they are struggling to find qualified welders let alone guys that are reliable. So many amazing opportunities out there for people who actually want to work.
Don't know if I ever recorded mine here. 🤪 Mine cracked at approx 25k miles, don't remember exactly. Haven't brought it up to the dealer because, honestly, it would end up being a passive aggressive sparring debate on if they were REALLY bad, if they're covered, blah, blah, blah. I'll get to the end of warranty with the cold tick and change them for aftermarket. Sad I have to wait on the lifter warranty to properly fix anything.
I'm confused on how they could argue or debate a cracked manifold or broken stud? If your truck is under warranty and your manifold is cracked then it's pretty black and white.
I finally received a call from my local dealership. They have confirmed both the sheared mounting studs and cracked exhaust manifolds . They have put me on a list and once the replacement manifolds become available they will call me and make the repairs. I’m considering going with shorty headers .
“Your manifolds are not cracked” o_O
Are dealerships rated on how much warranty they spend from FCA? I know it does pay less than customer pay.
You should find my post about oil changes at the dealer…
Well I have installed the JBA shorty headers. What a pain that was . Don’t recommend it unless you have tiny hands and long arms. I will post pictures when I get home.
