U
User_3336
Guest
So that's something you didn't explain earlier. The way your first post read, it sounded like the lift and tires were all done recently, not six months ago.
that was the impression I got when I first read it.
Because some people enjoy it or it adds value to them.never got the mod thing - throw more money into a money pit (any vehicle) that you will never ever get back - donate it to a dog shelter as least it will do some good
NoBecause some people enjoy it or it adds value to them.
Why did you get a 2019 Limited? You could of gotten a tradesman instead of spending thousands more for addition mods that a tradesman doesn't have?
See how that works?
Bad advice given his situation. They will not cover any vehicles with a raised suspension not using Mopar parts or installed by a dealer.Purchase the MOPAR EXTENDED WARRANTY. Ours has paid for itself 4 times over already.
never got the mod thing - throw more money into a money pit (any vehicle) that you will never ever get back . Reduce gas mileage, increase wear and tear, makes no sense at all. - donate it to a dog shelter as least it will do some good
See how that works?
So you spend more money to get a Limited with a bunch of extra options that reduce gas mileage, money that you will never get back, and question why other people enjoy customizing their vehicles?
Why buy the gas guzzling pickup? You can pop the hatch on a Prius and probably fit a yard and a half of mulch in it with the seats folded down. A little rope and you can strap most anything you want to the roof (just watch idiots on YouTube).never got the mod thing - throw more money into a money pit (any vehicle) that you will never ever get back . Reduce gas mileage, increase wear and tear, makes no sense at all. - donate it to a dog shelter as least it will do some good
Guess you’ve never got a new cell phone or TV, or ever eaten a steak instead of a hamburger? That could be seen as throwing money away toonever got the mod thing - throw more money into a money pit (any vehicle) that you will never ever get back . Reduce gas mileage, increase wear and tear, makes no sense at all. - donate it to a dog shelter as least it will do some good
Lol
Yeah I have to agree. I didn't consider the 3.5" lift and 35's to be radically modified either. If I had my way I certainly would've jacked it up much more and added many more modifications but I use the truck for work and I have to remain somewhat practical.
I've heard a lot of talk about the Tazer but when I looked into it it seemed to be more about setting up window opening parameters and fancy lighting sequences that do nothing for me. The tire recalibration thing is all I want and I wonder if there's a simpler way to achieve this ? That could very well be the source of my issue. Or it could be one of a hundred other electrical or sensor issues that seem to plague this truck. I find it hard to understand how it was fine for the first 6 months after the lift and bigger tires and only started after they were rotated !?
There isn't any app or plug in device that will adjust your headlights. Have to do that manually, which most people don't do. No need to change ge shift point, but updating for correct tire size would effect that as the RPMs vs speed will be different.I have the Tazer DT and its value to me boils down to 1) the newly added anti-theft layer (PIN LOCK) and 2) the side mirrors auto-fold. The first is obvious and the second is of real value for someone like me who frequents city parking lots with tight per-vehicle spaces.
As for recalibrating for modified lifts and tires, I'm not sure there's an available device that has a comprehensive suite of adjustments; speedometer, shift points, headlights leveling, sway related reprogramming... etc. I think all my Tazer would do is speedometer calibration.
Regarding your particular incident, It seems your lift/tire size are not the culprit since they performed well for 6 months. I would rather check the entire wheel well for any tire rotation mishaps. For example, any loosened wheel sensing device/cable or loosened brake assist device/cable, or improperly seated wheel, or missing wheel spacer (if applicable), or a warped disc or studs due to over-torqueing, ...etc.
Two of the above happened to me at different occasions.
My 300 has auto leveling headlights. Be glad they did not do this brilliant idea in the trucks. It's a little glitchy sometimes.There isn't any app or plug in device that will adjust your headlights. Have to do that manually, which most people don't do. No need to change ge shift point, but updating for correct tire size would effect that as the RPMs vs speed will be different.
My 2019 RAM 1500 Bighorn 4x4 has a leveling kit on it, that was NOT installed by the dealer. It has not effected our warranty.Bad advice given his situation. They will not cover any vehicles with a raised suspension not using Mopar parts or installed by a dealer.
It will only effect the warranty that the leveling kit effects. So if you go in for front suspension issues, or front CV joints, there is a good chance they will use the leveling kit as a reason the part failed and not honor warranty for that. but, no, it will not effect the entire warrantyMy 2019 RAM 1500 Bighorn 4x4 has a leveling kit on it, that was NOT installed by the dealer. It has not effected our warranty.
Yes, maybe more details are needed. How many miles are on the truck? Since this just happened, did you do anything else? Any brake work been done? Are the pads in good shape? Have you checked that one caliper is not sticking a bit? If you brake hard does it pull or act up in any way? Does the ABS work? Any play in your steering? Any bump steer at normal speeds? Any creaking or popping noises when you are creeping and the suspension articulates?
