My buddy bought a '23 Limited 1500 Hemi/eTorque last week. He received his Comma 3 on Friday. I received the mount from
@Malodave on Saturday (while I was out of town for the weekend). So, today I installed the Comma 3 in my buddy's truck for him.
We set his C3 up on the normal release of OP from Comma.
We started driving around and it displayed a message about Unable to get GPS position, or something like that. Under that it said something like "if your device has a clear view of the sky, you may have a hardware failure."
This dialog would display and not go away and it took up about 1/3 of the screen, making it very difficult to actually use OP.
Is this something that is normal, as a result of installing the C3 using malodave's mount, right below all those electronics behind the mirror, instead of gluing it directly to the windshield? The C3 is hanging down right behind the mirror, from the mount that attaches to the underside of the big plastic housing around the rearview mirror stalk.
We're wondering if my buddy received a defective unit and needs to do an exchange with Comma.
After a test drive to verify that everything else worked, but that GPS message not going away, we uninstalled OP and installed the SunnyPilot release fork for C3. We did another test drive and no GPS message. SunnyPilot seemed to work well.
The original OP would not steer the truck below 32 MPH, at all. SunnyPilot seemed to do steer-to-zero just fine. I was surprised that OEM OP would not steer below 32 - and I mean, at all. Even after driving above 32 and then slowing back down, it still would not steer.
Is SunnyPilot the best fork for running on a '23 RAM 1500, or is there a RealFast or other fork that would be better?
@Malodave apologies for sending you basically the same questions in PM and then posting here as well.
