colored Ambient Lighting (Dash and Doors)
Just finished the install. It took about 1 1/2 hours. It was a very easy install and the directions are very good. I had ready replaced my door speakers so I knew how to remove the panel. The hardest one I had was the front passenger side foot well. The fabric panel cover was a pain to remove from the hard plastic glove box lower. I will get pictures when it gets dark. The company was very easy to deal with, I contacted them on FB messenger, they told me the price, and then sent me an invoice through paypal. The LED's showed up 3 days later.
hmmm....:unsure::unsure:i think will go to"PepBoys" and just buy those little 4"strips and leave it at that.i will do like i use to back in the day and fuse it to the "Dimmer"(IMHO)!
I did the dash... You can check it out in this post:
Here are some pictures from my install. Install instructions are very good and should relieve any fears. Customer service is fantastic. I bought directly from. Ryan via facebook. Good company to buy from with high quality parts. Inspection of replacements shows they to be OEM quality at least.
looks really nice!
Can this be installed on a bighorn? Aside from the dash line I think my panels have all of the other holes for the LEDS and I have the ambient lighting wheel on the left side of the steering wheel (two adjustment wheels total)
I plan to change out my base speakers so I might as well do this too while the panels are off
Unfortunately no. They're working on a Bighorn version. It might look like it but you don't have the necessary hardware in your doors and dashboard.
Oh I see. I may have to make something up then. Maybe using the lights you have on your dash but in the doors, to allow the light to pass through the holes??
Is yours wired to the interior lighting? I may splice into the something if possible.
I would prefer not to implode my truck.
Mine has a + and - that are plugged into a fuse. Not to the interior lighting switch...
Where can I get this? Does it utilize the factory wiring? I have a 19 rebel and the light holes are all there. Does it dim with all the other ambient lighting? Sorry for a million question but I've been searching for this ever since I found out it only comes in laramie and up. Also do they offer it in red if love to keep the rebel red theme throughout.
if there will be a group buy,
I'm interested and sign me up.
I have a 2019 DT Laramie the only one in Qatar in the blue streak color, I was thinking of painting the interior dash and doors with a small blue accents just like the rebel, in the same time if those can be changed to a combination as in the photos the blue looks very bright and overkill.
a multicolor I can wait if it will be available at least a mixture of white and blue together.
I've done plenty of XBOX & PSP LED changes, these don't seem to be that much more difficult -- other than the "style" of LED FCA uses. I'll pull one out and see if they can be changed over -- more than likely, they are surface mount which are a bit more challenging if you do not have the proper soldering equipment.
Hey i was wondering if you ever got around to switching out the diodes on the new style footwell lights.
No, sorry. After the initial look, I forgot to try it myself (and work has had us 5-6 days a week 10+ hrs per day). I'll go pull one right now and look into it .. thanks for reminding me :)
I too wish they could give a estimate of cost.
i search for paragoptics, nothing found. Doesn’t necessarily mean anything if they do not have a site.
but a company using yahoo email address does.
Here is a pic of what the LED under your driver's knee looks like.
LED2 is easier to replace if you have the right soldering iron (LED1, notsomuch)
PIN 1 Ground
PIN 2 -- EDITED -- NOT USED
PIN 3 Positive for LED1 (really bright entry/exit - Courtesy)
PIN 4 Positive for LED2 (dimmer Ambient Lighting - Premium Only)
Now, you can always cheat and just swap out the lens' or "dye" them (maybe translucent model paint? I also have red and blue cellophane paper from decades ago that I may try as well).
The DOMED one is the LED1 cover while the flat square is the LED2 cover.
