Towed my small hard sided popup down to GA this past weekend for an event. I had just passed 1k miles on the way to get it out of storage at my brother’s farm before the trip so I wasn’t worried about towing on the engine break-in period, but I’ve now crossed 2k. Snagged a pic as I parked it, but you can tell the truck was being used as a truck, even tho it’s a fancy-dancy Limited
Had the rear seats folded up and several hundred pounds of tools in large plastic totes; the flat floor made getting them in and out much easier. The underfloor storage is perfect for ratchet straps, spare hitch accessories, jumper cables, gloves, safety vests, magnetic base led lights, etc. I definitely appreciated the backup camera and air suspension for making hitching up and dropping the trailer quicker, and the trailer detection for the blind spot monitoring worked fine.
Towed at 70-75 mph from IN to GA through Chattanooga, and had no issues with 15+ mpg. With tow mode off, eco mode engaged without issue whenever I was in slower traffic. All of the trip was in rain, and the place I was headed to has some very well worn gravel “wishes it was still gravel”
paths with a slick coating of red Georgia clay on top, but the stock tires with a quick set to 4wd auto climbed right up the hills that some other folks had failed to get up. didn’t try in 2wd, but the way it went up the hill I’m sure it would have been fine.
The trailer is a Rockwood A122-SESP, and has 2 batteries & 2 propane tanks on the tongue, plus several totes under the bed (aft ofthe door/over the axle), plus quite a bit of weight forward with a bunch of tools under the table (Forward of the door) and weight from 5 gallons of gas and an extra full Blue Rhino & portable heater I brought for an outdoor pole barn in the big storage compartment on the front of the trailer. Not like it’s a heavy setup, but about 3k as loaded.
