CMil527
Hmm definitely had to adjust mine a bit but fitment was pretty good.. contact Borla with pics maybe you received one with a bent or misaligned hanger that is throwing everything off.
I'm not saying you installed it wrong but I find it hard to believe that the entire setup has poor fitment, especially from Borla. I would say contact them and see what they say but maybe just ask a muffler shop for some advice.Well, I got the Borla S-type and installed it today. For the price, I have to say that I'm very disappointed in the fitment. I need to contact Borla about this. Here's what I found for issues from front to back.
1. The front hanger, with the front of the muffler bolted up, does not fit into the rubber isolator. The hanger hook wants to go through the same isolator hole that's connected to the truck. I think I saw someone else mention this as an issue with their's also. I turned the isolator and have the post going thru a wrong hole just so it has something to hold it up. (pic 1)
2. The muffler can is only a hair away from the frame, so the lightest touch and it bangs on the frame. There's no clearance at all. (pic 2 and pic 2_2)
3. The passenger side pipe is also touching the jounce bumper mount. (pic 3 and pic 3_2 )
4. The passenger rear hanger is not staying on the isolator and keeps coming loose, allowing the tip to not remain centered. (pic 4)
He's not the only one! There's several other threads regarding some of these fitment issues on the Borla systems for the 5th gens. I just installed the Borla Touring myself on Saturday. I managed to remove the stock exhaust without cutting anything. Removed the spare tire and shroud and that provides plenty of extra room to get the stock exhaust out without cutting it. The touring muffler installed without issue but I am experiencing the same issue where the passenger side pipe comes in contact with the bump stop. I managed to manipulate it such that it doesn't touch (though still closer than I like) and by doing that I can't get the tip to align perfectly centered. I have OCD so it won't be staying like this and I plan on revisiting the install this coming weekend. By the time I finished removing the stock exhaust and fiddling with the Borla I was completely "exhausted" (and frustrated). With the price they charge for these systems there shouldn't be any fitment issues. I love the sound but if I can't get the fitment worked out I'll be sending it back.I'm not saying you installed it wrong but I find it hard to believe that the entire setup has poor fitment, especially from Borla. I would say contact them and see what they say but maybe just ask a muffler shop for some advice.
That sounds like a very reasonable solution. My issues aren't quite as bad as yours but if I can't get it taken care of by myself this weekend I will email Borla and ask them if I can do the same.I just spoke with Ryan at Customer Service. He suggested that I go to a reputable muffler shop and have them make any necessary adjustments, up to a specified dollar amount, and they will reimburse me. He asked that I send him an email so he can reply with the reimbursement guarantee. I will do that. That is probably a cheaper option for them than replacing the entire system. I think they need to go back to the drawing board with their design team and have a system, off the shelf, installed on a truck so they can see these issue for themselves.
If you're looking for opinions I'll certainly give you mine as I'm pretty much in the same situation as you. If they gave me that choice (and I hope they do) I would most definitely take it to a shop and get the pros to take care of it. Probably won't take them that long and that sure beats having to remove the complete system and reinstalling a new one and potentially facing the same issues again.I actually received two emails from Borla. I emailed them with all of the pictures and a description of the issue. I then called them late yesterday afternoon since I didn't hear from them. The person I spoke with at customer service said to take it to a shop and they will reimburse me the costs. Today, I got an email response from someone else asking me to provide them my purchase details and they will replace the system under warranty. I wonder which direction I should take...
Dang it. I installed my S-Type on Saturday and the passenger side was touching the bumper. After tinkering with it for an hour I called a local shop and they said I could bring it in within an hour so I jumped on it because I didn't want it damaging my bumper long term. Cost me $70 for them to cut the pipe near the passenger tip and put a coupling over it to then align it properly. Also had them tack weld the three clamped areas so I don't have to worry about them vibrating lose. I didn't take any pictures or anything because I wanted to get it knocked out that day so I bet I can't get anything back from Borla.I just spoke with Ryan at Customer Service. He suggested that I go to a reputable muffler shop and have them make any necessary adjustments, up to a specified dollar amount, and they will reimburse me. He asked that I send him an email so he can reply with the reimbursement guarantee. I will do that. That is probably a cheaper option for them than replacing the entire system. I think they need to go back to the drawing board with their design team and have a system, off the shelf, installed on a truck so they can see these issue for themselves.
New question for the Borla crowd. Do the tips have weep holes in the bottom? Mine doesn't, so when I washed my truck, the tip filled with water up to the pipe . Is my set totally messed up, or no weep hole is standard?
My borla ATAK tips do not have weep holes eitherNew question for the Borla crowd. Do the tips have weep holes in the bottom? Mine doesn't, so when I washed my truck, the tip filled with water up to the pipe . Is my set totally messed up, or no weep hole is standard?
