Just to add a little to the reliabilty aspect of these engines. I have a 2019 with the Hemi and it has not been that reliable imo. I have had several spark plug failures for unknown reasons which the dealership could find no issues. I will most likely be upgrading to the I6.My point is you completely missed my point. I'm not interested in something that is marginally faster than the 5.7 (or the HO which I wouldn't get anyway). All I really care about is reliability. How many generations of the 5.7 were there? It's been around a while. Plus my '23 is near the end of the 5th gen cycle. That is what I look for. Where are the reliability numbers on the brand new '25 that isn't out yet? Those numbers don't exist. I am a gambler, but not going to gamble on a 1st gen motor in a new model year 1500. Hard pass!
Also, finance wise, similar to buying a '23 when when the '24 are near the end of their production year, I like to wait and try to save money. So if I had waited until the end of the year, I would be looking for a '24 that the dealers are trying to get rid of because the '25 would be out. Clearly not rushing to buy the first '25 that makes it to the lot.
I do wish the early adopters luck and hope it proves to be more reliable than the 5.7. Until thousands have put on the miles, we just don't know those metrics.
You have to remember that the Hurricane is also doing this with 2 less cylinders
Mine ended up being same cylinder both times. I replaced just that plug and coil first time then all plugs and coils second time. Used NGK both times. So far it’s been 10k miles and no issues but we shall seeHave you done your own plug changes and use NGK?
I've had 4 Hemi's and changed all 16 plugs many times without a single issue or plug failure using Champions or NGK, so seems quite odd to me.
Is it possibly a bad coil pack?
Doesn't that mean the smaller engine is doing the same work as the larger engine thus putting more stress on the engine and not lasting as long.
The turbo on my 2022 inline 6 Cummins seems to work pretty well, is reliable and get good fuel mileage.Even ford doesn't put turbos in their real trucks. Instead their super duty's have a large, simple, NA pushrod v8 like a real engine should be. The reason is exactly as you suggested, tiny turbos can't handle the duty cycle and on top of it they get very bad MPG when working hard.
The 5.7 hemi isn't flawless, but its been proven to take the abuse in the 2500 trucks for many years. This was one of the attractions to the Ram for me when I bought my truck 5 years ago. As long as there is a v8 to purchase, that's where my money goes.
I don't disagree with you that Ram is making a mistake not offering a 1500 with a V8. But I am disagreeing with you about your first statement. Unless you don't think an F350 equipped with a large displacement turbo diesel is a real truck that is. But I guess that depends on your definition of what a "real truck" is. I was raised with the definition of a 1-ton or bigger is a real truck. Anything less is a pickup.Even ford doesn't put turbos in their real trucks. Instead their super duty's have a large, simple, NA pushrod v8 like a real engine should be. The reason is exactly as you suggested, tiny turbos can't handle the duty cycle and on top of it they get very bad MPG when working hard.
Ill take a turbo diesel over an turbo gas engine any day... Not apples to apples imo.The turbo on my 2022 inline 6 Cummins seems to work pretty well, is reliable and get good fuel mileage.
So then the Hurricane on the 1500s make sense.Edit: and just to clarify, maybe a poor choice of words but "real truck" to me means heavy duty. The half ton segment is no longer truck focused, it's much more of a passenger car. The trucks that work hard are the 3/4 and 1 tons.
The Hurricane is not running within and inch of its life. You clearly don't understand turbo gas engines.The hurricane is a tiny motor with a turbo that is wringing it to within an inch of its life every time it runs. It's a light duty passenger car engine.
I don’t understand why you’re getting so worked up about this If that’s the case. If you want a “real truck” to do “truck things“ why do you have any interest in a half ton pickup in the first place? If half tons are “more of a passenger car” in your opinion, why aren’t you driving a 3/4 ton or 1 ton?Here too the 6.7 is a large displacement motor and built very tough. Diesels are naturally far stronger built as they have to withstand the intense pressure and heat from compression.
Most semi trucks pulling 80k pounds are inline 6 diesels. The hurricane's issue is not that its an inline 6 with a turbo. It's because its a tiny lightweight engine designed for car duty.
Again, why do you think Ford didn't stuff their eco boost in their super duty? It puts out similar torque/power numbers vs the 7.3 and/or 6.8, yet they went through all that trouble to design a new engine from the ground up specifically for this truck and campers and ambulances etc. These engines are built to a completely different standard and there is a reason they're not small displacement with turbos dialed up to level 1000.
take picturesThe
The fifth one is about an hour from me so I might go give it a try when it comes in. Its sort of at a dealer in the middle of no where which is funny.
Ummm what?
Turbo Diesel in addition to two gas engines. The gas engines are there as a cost savings to the customer, every 2500 I've seen with a gas engine was struggling with a simple 5K trailer
Try reading the bolded part over and over again until it makes sense for you. They don't put their ecoboost gassers in their trucks, they use large NA gassers.
And don't make me laugh, gassers are towing > 15k pounds these days and its obvious you haven't had a second experience with them.
