DanSkan
I've got the 4x4 with e eLocker and love it. When I know I'm in a place that I might need extra traction I just push the button and the light light comes on and both rear wheels lock in without only one spinning and I drive right out sometimes in 2wd and sometime in 4wd.
Antispin would work just as well most of the time but not all the time. Traction control is not the final answer because first a wheel needs to spin for it to know to engage and then engine limiting control and applying brake on the spinning wheel. Sometimes you dont want engine control and you don't want to apply a brake to a wheel when you trying to get out and want to turn the traction control off.
E Locker doesn't wait for a wheel to spin, some times when a wheel spins it is too late and you get the best traction before the wheel starts spinning.
I have a steep curvy loose stone driveway and most trucks will start spinning one wheel, a lot with open diff, and a little with anti spin or until they turn on the 4wd. With e Locker there is zero spinning, both rear wheels lock in and 4wd is not needed when there is not ice or snow.
With ice and snow 4wd and eLocker drives right out with no spinning most of the time - sometimes you are spinning 3 wheels all the way out and feel lucky you made it out.
4wd low turns off the traction control so don't have that to rely on.
I have traction control on other vehicles and it is good to slow the throttle down to try to keep you from spinning but when I'm stuck or getting stuck I turn the traction control off to get more control, Rev the engine up a little, get the
tires moving and get out.
