Quick comment. No offense, but a lot of people are simply guessing. This guy commenting above me is CORRECT. I cant believe no one here hasnt torched a limited slip diff! It is NOT an open differential. It is a TRIED and TRUE principle used in cars for decades and decades. It is the engagement of BOTH axles via clutches by essentially locking the pinion gears. This operation is operated by the torque applied to the axle assembly. It really is the BEST option for us mall crawlers that do NOT offroad in sticky mud or sand. Its sole purpose is to provide max torque to both axles when you have it floored or apply torque aggressively. When you make a turn and let off the throttle, the clutches disengage allowing the outside wheel of the turn to slip or turn a higher speed than the wheel on the inside of the turn. Then, you finish the turn and floor it again. Both wheels lock. Period.I think some members need to do a little more reading about the trucks they're driving. One shouldn't be guessing what a button does in the middle of rush hour.
For those first time 4x4 owners, open and antislip rear end gear sets always allow differing levels of slip. Obviously the open diff means one wheel is the drive wheel. The antislip diff applies power to both wheels (via clutches or braking) at times of reduced tranction or aggressive driving. BUT, will always give smooth cornering and better perceived handling in corners and tight situations.
The locking diffs, be they mechanical or electric, LOCK the diff, giving posi traction, equal distribution to both wheels. You do not want to be taking corners on dry streets with the diff locked... you will find out quickly from the hoppin and chirpin what a locking rear feels like at the wrong time.
I know this has been covered a bazillion times but maybe my simplified explanation might trigger a few searches in the future and save any of us from having to go through another 4x4 e-locker discussion for beginners.
Drive an open differential equipped car/truck in the rain and let me know how that works out for ya.
An e-Locker is a pneumatically, hydraulically and now electronically actuated differential that does the same as above but WITHOUT clutches. Its usually a locking pin that engages both axles through the carrier. So, when you make a turn with it locked, NO wheels will slip. You will hear it bark the tires and it may hop around turns if you are too aggressive. NOT good for constant street use while always locked. This is what you want if you off road frequently. The advantage is that you don't have to apply torque aggressively to lock the axles. They will ALWAYS be locked when engaged. Perfect for rock crawling.
I'm an old Mopar guy. After all these years, the Dana 60 LSD still requires 75w-140 (3.92) with 5 ounces of whale sperm. This is the limited slip additive that protects the CLUTCHES. Hasn't changed is freakin decades.
