I picked up a 2020 Ram 1500 Big Horn Crew Cab 4x4 with the 5.7 eTorque and the 3.92.   Drove from Atlanta to South Florida and got 19.8 mpg highway driving at between 75 and 80 MPH.   Way better than what I expected.   Hell, my wifes 2012 Nissan Pathfinder 4x4 with a 4.0L V6 only gets about 17 MPH under the same conditions.   I expect the number will drop a bit when I put larger AT tires on, but still.    I don't buy trucks for their fuel economy, but color me impressed by this one's so far.
First time out on the highway for any meaningful distance since I had the mild level/lift and AT tires installed.    Bilstein 5100s front and back. Front set at #5 (1.7 in lift).  Rear 1 inch motofab spacer.   275/65r20 AT tires on stock 20 inch wheels (34 inch tire vs 32 inch stock).   So in the front she is 2.7 in higher than stock and 2 inches higher than stock in the back.
Highway mileage dropped from 19.8 to 17.7 mpg (taking account the 6.5% difference in mpg computer reported vs actual - 16.6 mpg was reported by the vehicle computer) .  I was driving at ~75 mph (again taking into account the speedo error due to the 34 inch tires).
So the drop in highway mpg that I experienced was 2.1 mpg.  I am not surprised.  I raised the front 2.7 inches.  The way FCA had the front of these leave the factory was really genius from a highway mpg perspective.  With the fixed front air dam spoiler already low, plus the additional active air dam that deploys above 35 mph, they have really minimized air flow under the vehicle.  If you look under our trucks (or any pickup for that matter), there is a lot of stuff for air to get caught up in underneath these vehicles, create a ton of drag.  By lifting the front end almost 3 inches, I have introduced a lot of additional drag.
Of course I knew this was going to happen when I lifted it.   I was expecting to lose between 1 and 2 mpg.  I only drove about 140 miles so the initial estimate of a drop of 2.1 mpg may change a bit, but I expect it to be pretty accurate.
I still consider the highway mpg to be great for a mildly leveled/lifted 1/2 ton truck.   Aerodynamic
drag increases with the square of speed.  So if I want to improve my highway mpg I will need to be willing to drive slower, maybe 65 mph instead of 75 mph - doubt that's going to happen.  But if I did, I should see a significant improvement in fuel efficiency.   By dropping from 75 mph to 65 mph, you are reducing the force required to overcome drag by 24.9%.
And there is probably a sweet spot on these vehicles, max speed where the truck will still utilize eco mode on the highway to improve mpg.   I wonder what that is for a stock truck, and now for my truck.  I noticed that my truck after the level/lift would never go into eco mode over 65 mph on the highway (unless descending a slight grade).   I didn't think to check that before I raised it.   I am going to try to figure that out on one of these trips for my truck now the way it is setup.
Edit:  Inspired by being referred to as a nerd by EEnginerd, I decided to update my post with the other two variables that differed from my original MPG observation.    1.  I now have a Tonneau cover on the bed.     FYI, objective MPG tests of Tonneau covers on pickup truck beds show no difference in MPG with or without Tonneau cover.   2.  I now have running boards.  This probably adds a little bit of additional drag but I did install them tucked in behind the front wheels.
