And How!Nice mileage for that much city.
I do not have larger tires, but I do have a 2021 EcoDiesel with 3.21 gears. The most annoying characteristic of this truck to me is that there's no way to lock it into a gear. My previous long-haul vehicle was a VW Touareg TDI, also a 3.0 V6 diesel with an 8 speed (Aisin) transmission. As soon as I got up to highway speed, I would move the shifter over to the right into manual mode, which would keep it in 8th gear. The RAM does downshift out of 8th more than I'd like, particularly with the adaptive cruise on. I wouldn't exactly call it "hunting". It downshifts to get back up to speed quickly, and it sometimes does so on hills, but I think it does so unnecessarily. With 480 ft-lb of torque at 1600 rpm, it really shouldn't have to do that.Now, looking for real-world reports of the EcoDiesel with 3.21 and larger tires, like 34" or 35" and how the transmission works at highway speeds. Does it hunt 7-8-7-8? Or, does it comfortably shift into, and stay in, 8th gear at highway speeds with an ecodiesel and larger tires?
Hi all. I registered just for this discussion and have read every message. Thanks to the OP for the explanation that kicked off this thread.
I'm trying to decide between two 2021 EcoDiesel Rams. One's a Laramie, very well equipped, with the 3.21 and one is a Rebel, modestly equipped, with the 3.92. The prices look to be similar here at the end of the year. Payloads are about the same. The Rebel is rated to tow about 9,750# and the Laramie about 8,150#. We'll be towing a travel trailer with a max weight of 6,200#. We're in the NC foothills, but plan to take it all over the country over the next several years.
Anyone have experience with this particular scenario? This would not be a daily driver, but when not used for truck stuff near home it would be for longer trips with and without the camper. I see a lot of people wanting the 3.92 for passing, etc... but I've never had an issue being able to pass someone in almost any vehicle. My daily driver is a 150hp Mazda 3 and I can get around people fine. It's a lot lighter than a truck, of course, but gives up a lot of power as well...
Anyway, I'm curious what to expect when towing the camper, particularly from a standstill. I've got to think that the torque of the diesel would help the 3.21 pull sufficiently off the line?
I'm leaning toward, but not yet sold on, the Laramie only because I don't think we will do the sort of off-roading that the Rebel might be better for, it has some of the safety features that would make me feel better when my wife is driving, and I do like getting good mileage.
Thanks for any guidance you can offer!
3.92 means better acceleration as well not just better towing capability. However it means lower mpg efficiency (anywhere from like 1-4 mpg’s I think, depending on what engine you get. I was gonna get the 3.21 in my ordered ‘21 Limited EcoDiesel but I went with the 3.92 because at the time the Off-Road Group required it, glad I got it really for that slightly better acceleration (supposedly).Potential owner question - I am eyeing up a few options in my area and the new Laramie 1500s I’m looking at have 3.92 ratio. I live near St Louis (relatively flat) and wont be hauling/towing much. Should I hold out for a 3.21 or will the difference between the 3.92 be negligible in my situation (gas mileage/handling/etc)?
Do you really feel a difference in the performance?traded in my 19 3.92 in on a 21 3.21 already noticing a improvement on mpg and a lot lower rpms on highway
Its the square of your right foot BIG TOE, to most truck owners.Any idea on what the gas mileage difference is between a 3.21 and a 3.92?
with me it has been 1-2 mpg difference on mix driving but mostly highwayIts the square of your right foot BIG TOE, to most truck owners.
No i Feel it’s the exact sameDo you really feel a difference in the performance?
my same opinion after owning both axles. The 3.21 definitely feels sportier to me as well. This is why I went back to 3.21 in my 2021Just spent a month driving a '20 Laramie with 3.21 axle and now have a '19 Limited with 3.92. It might be partly the extra weight, wheel size, suspension, etc but the 3.21 actually felt like the more sporty of the two. More tempting to goose a little going up hills and onto the highway., just purrs and goes.
I have a '21 ED with 3.21. I'm glad I chose it because 3.92 with stock tires would be too busy for my use (mostly highway driving). But if I were planning larger tires (which I'm not), I would have spec'd the 3.92.Is my inexperience causing me to overlook something?
