- Apr 11, 2019
If your truck is Canadian, these settings will put the radio menu item to toggle DRLs on and off:I’ve done some searching and a ton of reading but can’t figure out if there is a way to completely turn off all lights with the headlight knob while the truck is in gear. Would setting the drl up like a USA truck do the trick or is it not possible? I don’t plan on using this on public roads, just mainly old forest roads and private land etc.
CBC Features: DRL Configuration- Optional
CustSetMenu 1: Daytime running lights CSM Present- YES
Then, to turn the separate signature lighting feature off (upper and lower strip that are on anytime the truck is on):
CBC Extern.Light Calibr.: Signature Light Present- NO
