Edmontonram
- Jun 18, 2020
Hello everyone, new guy here. I've been reading up on all the Alfaobd stuff and trying not to repost without searching first. So I picked up an MX+, Z Auto bypass module, and have Alfaobd loaded on my windows PC (Downloaded OBD link for iOS just for mobile code reading or whatever).
Question, is there a sticky to a thread with known working configurations for Alfaobd? (I have a Ram 2020 Limited).
Essentially what I'd like to be able to do:
- DRL delete -> see BCM -> Car Configuration Change -> “CBC Features - DRL Configuration”
- Having option to turn off all lights including LED strips with lights off (Some people have been posting about this asking if it is an option because apparently they are always on with ignition) -> not available/not known
- Seat belt indicator/warning turn off -> see Instrument Panel -> Program Customer Features -> Seatbelt Alert System
- Window roll down with keyfob (I think this is labelled universal window roll down) -> see Driver/Passenger door -> Window Global Down Enabled/Disabled and BCM -> Car Configuration Change -> “Doors - Global Windows Down” (sometimes it is sufficient to enable the option for door modules only, sometimes also in the BCM)
- Mileage changes -> see Instrument Panel -> Odometer correction
- DPF soot indicator on dash (Diesel version of trucks - I think the 2500/3500 version of trucks have this but not the 1500) -> not available/not known
- Regen active message for all regen cycles (Diesel version of trucks) -> not available/not known
- Mirror auto fold in on truck off -> see BCM -> Car Configuration Change -> “Doors - Folding mirrors present”/” Auto Power Folding Mirrors Present”
For the options marked “not available/not known”, this means that I have no information, maybe these options are enabled indirectly when some other option(s) enabled/disabled. Maybe they are set in the BCM internal software and not adjustable. If they can be set in the BCM configuration, to detect the right setting I can only suggest to compare the configuration of a car which have them set with the configuration of the car where you want to set these options
Those replies are from Alexey (Alfaobd).
Any guidance would be greatly appreciated!
This is a great list! Do you have anymore of these settings? I would love to start a list of these.
