- Apr 11, 2019
You can correct the mileage on the 5th gen clusters with AlfaOBD, but it can’t do the hours.So far as I can tell with the search function, no one has updated the odometer. I've upgraded the gauge cluster with one from a limited. I've went through the steps to update the odometer, but no luck. Maybe I'
m not letting it "sleep" long enough.
Security bypass installed, newest version of AlfaOBD, connected via OBDLink MX. I've successfully done other things like adjust tire size, seat belt dinger, fogs with high beams. Just can't get this to adjust.
Any tips? Thanks!
New and Old
The only quirk that’s different from the 4th gens is, the number that you enter for you miles needs to be closer to the equivalent of that number in kilometers, but not exactly.
So, if you’re wanting to correct to your old cluster’s 59323, enter 95471 in AlfaOBD, they fine tune adjust from there.
