Dookie
Learned something new today, so thanks.
			You can enable auto parking brake in the truck. I have mine set up for that. When I put trans in park it automatically applies parking brake. And as long as I have my seat belt on, it releases parking brake when you shift into gear. All without ever having to touch the buttonThat’s how I was turning them off while parked with the engine running, but it gets old engaging/disengaging the parking brake constantly. So now I’ve resorted to just turning them on through the radio when i want them on.
Did you try enabling DRL dropout?That’s how I was turning them off while parked with the engine running, but it gets old engaging/disengaging the parking brake constantly. So now I’ve resorted to just turning them on through the radio when i want them on.
Ahhh okYep. That just turns off the DRL on whichever side a turn signal is actively being used.
I feel this option doesn't actually work the way it is being presented. Maybe OP can put an asterisk next to it saying it doesn't work for most people.I cannot get the drl’s to drop out when the turn signal is activated. I changed everything listed. My voltages were at 12.2 already. Not sure what the parking voltage is but they definitely dim when the parking lights are turned on. I also cannot get them to turn on only in gear. They are on all the time. Signature Light - No turns them off completely as DRL’s. They won’t come on in gear or changing the radio setting. Setting to Yes turns them on (even in park) and the daytime running lights toggle in the radio does nothing as well.
I must be missing something.
Update - I enabled the options "Off-Road Capable" (was on already since I have ORP), "Display performance pages", and "Display Off-Road Pages". I now have the off-road and performance pages on my 12" radio. However, I dont have them on the EVIC. Im on the latest PR39 update. My truck is a 2019 so maybe I won't get them on the EVIC? Wondering if anyone else has tried and knows. Thanks!
Cool. Wonder if there's any sort of BCM updates that would give us the EVIC screensMy 2019 is the exact same.
Yeah, I'm glad mine are on the 12" screen.Weird how pre 2022’s seem to be getting them in the radio and not the EVIC and 2022’s are getting them in the EVIC and not the radio
Just wish the timers and gforce sensors actually worked on mineYeah, I'm glad mine are on the 12" screen.
same here. Wonder if there is another setting we missedJust wish the timers and gforce sensors actually worked on mine
I've seen 2021 guys say they work as well. Might have to do with trim level and if they tlhave the off-road pages from factory. Probably why the 19/20 guys don't get them in the EVIC either as it was never an option.I wonder why all the sensors and timers work with mine? Maybe because being a Rebel and already having offroad pages means the g-force sensors are in place? I admit its pretty cool having them in the EVIC and being able to do 0-60, 0-100 1/4 mile, braking etc. most of the gauges are in the offroad pages but the HP/Torque calculator would have been cool to mess with.
FYI to others, there may be another applicable setting here but I can’t confirm if it’s mandatory. I was messing with this tonight because although I have BH Level 2 package I don’t recall ever seeing the flashing indicator on the dash._____________________________________________________________________
Vehicle Theft Alarm Enable:
LIN and Misc: Vehicle Theft Alarm (VTA) System State - VTA
CBC Config I/O: Connector A Pin 11: Hood Ajar Switch Input Present - Yes
CBC Config I/O: Connector G Pin 2: Vehicle Theft Alarm (VTA) Warning LED Output Present - Yes
CBC Features: Vehicle Theft Alarm (VTA) Hood Ajar Monitoring - Yes
That's interesting. I went through these a couple of weeks ago and also confirmed mine was all already set correctly but did not have the light. I might have to try this.FYI to others, there may be another applicable setting here but I can’t confirm if it’s mandatory. I was messing with this tonight because although I have BH Level 2 package I don’t recall ever seeing the flashing indicator on the dash.
For me, all but the last setting were already configured as shown above. I also found:
ECUConfig3 VTA System Present: No
I changed both of these to ’Yes’ and I now have the indicator light and suppose it’s working as intended.
