Those funtions dont work because your trans and bcm dont have the sensors to supply the data….
If those DATA show up on the UC4 screen, then they are available from the ECU and BCM. Showing them on the DIC is another issue.Those funtions dont work because your trans and bcm dont have the sensors to supply the data….
I don't know what software he is running, but the pages stop working with the 39.7 update if the truck did not came with the pages enabled from the factory. G-force pitch and roll should be in the Airbag module, I think.The way I read it his were showing but not working on the big screen.
I added the pages and some gauges work but no g force data, no pitch/roll,
and the launch control function and some other things dont work.
There is no going back, unless you can find a radio module with a software prior to 39.7Maybe thats my issue. I am running 40.1.0
Is it possible to go backwards?
Are they still in the cluster, just not on the radio? That’s what happened to mine too. I tried the toggle Alfa and nothing. I factory reset the radio and they came back for about a day and then disappeared again. They are still there in the cluster, but not the radioI added the off road pages via alfaobd last week. They worked great, roll and pitch sensors, the performance page as well. Today, get in and they are both gone. Check bcm settings with Alfa and they are still all set to yes. Any ideas on why and how I can get them back? I tried toggling from no back to yes - no joy. TIA
Nope, gone from the cluster too. Weird and I can't get it back. It's like FCA found out and reset me!Are they still in the cluster, just not on the radio? That’s what happened to mine too. I tried the toggle Alfa and nothing. I factory reset the radio and they came back for about a day and then disappeared again. They are still there in the cluster, but not the radio
That’s actually what happened. You need to disable connected services in alfaobd. If that doesn’t work, you need to remove the telematics box in order to keep them.Nope, gone from the cluster too. Weird and I can't get it back. It's like FCA found out and reset me!
