Hot weekend this past long weeeknd drove the truck all 3 days.I fix alot of AC units on heavy equipment as well as highway trucks, done it for so long i put the back of my hand at the vents and i can tell within a few degrees ifthe system is low 40's, my truck is not. Grab the thermometer and passenger side is 43, drivers side is 52 as many others have stated. This is 100% a blend door issue. If the ac system can bring one side down to 43 its oprerating to its capabilities. When I see a proper operating system but vent temps arent cold I immediately go to the heater taps and close them in heavy equipment. In doing so it eliminates any faults inside the plenum box. When doing this and vent temps drop you know the problem is in the dash....such as broken blend door, bad actuator or in the modern day age computer not telling actuator to close. GM and Chev had a whole bunch of trucks in early 2000's that would do thesame thing but put out heat on one side and ac air on the other. A reset of the sytem would fix it sometimes for a long time and sometimes ony for a week or two. I will give the dealer one time to fix it if they cant I'm installing the heater hose shutoff the problem will be solved.
