Thanks Cross88, these 32 pages and 500+ posts show that not only did FCA mess up big-time by not admitting and fixing the issue but that the forum is an invaluable tool for owners. Things like this as well as other fixes really are a positive for your and other's ingenuity. Your pics and hopefully soon to be posted results (hint) are great!
So glad this hack worked, its a lot of truck to cool. With so much great design in this truck, what was FCA thinking?FCA and Ram Trucks should hire KcRay for his efforts to help frustrated owners. They should bring him on as a consultant! Thanks man, you're the best!![]()
It would be nice to know if the a/c hack works on the older body 2500/3500s. Did the 2019 2500/3500s convert to new refrigerant?
Curiously the old body 2019 1500 hasn't had any complaints as far as I know - maybe it didn't convert to the new refrigerant?
No matter what the dealer or the service people tell you when a r1234yf system is working properly it will cool with the exact same effectiveness as the r134a refrigerant.
This ridiculous myth that the dealers seem to be spreading to the public is an absolute patient falsehood.
As proven by clamping off the heater hose, and getting 40 deg temps.We have a 2019 Jeep Grand Cherokee too, and it uses the same R1234yf. The a/c gets soooo cold, you have to turn it off, so its not a refrigerant issue, its a design flaw in the RAM's.
I know people won't read 32 pages, but, that myth has been busted several times, but please people, don't let your dealer tell you it is because of the new refrigerant!
The only way to keep it in the 40’s is with the valve closed, opening it up even a little and it’s in the 50’s!
Needs to be 12 volt that one is 110Wouldn't something like this work for guys that are having weather changes and don't want to open the hood and adjust every day (which I don't blame them)? I know this is not a 5/8" but just for the idea. Let me know your thoughts... https://www.amazon.com/Electric-Solenoid-Normally-Closed-diesel/dp/B007N0J98E/ref=sr_1_2?keywords=5/8"+electric+shut+off+valve&qid=1569075827&s=gateway&sr=8-2
Plug it in to the inverterNeeds to be 12 volt that one is 110
Not true, I'm in the desert at 115 degrees all the time. With the AC hack I can have my super hot cab cooled down in no time - even if I just idle. Yes, I do have the panoramic roof, too. I've tested everything and put a video together I am going to upload to youtube. With the AC hack in place the AC performs just as good as the best of vehicles and better than most. This issue is completely isolated to the mixing door.Like most, when my truck idles, im in the low 60s. When driving, I'm in the high 40s. Seems to me part of the issue could be a Freon volume flow issue. We need a hack with a higher flow rated compressor...….
I took a few pictures, and need some assistance.Does anybody have pictures or locations for clamping the hose on a 3.6l V6? I can’t figure it out from the V8 pictures. My temps are 53F after 30 min idle with ambient temp of 92F.
