vincentw56
- Aug 5, 2020
MicroWhat SIM type fit the slot?
Mini or Micro Sim?
Mini or Micro Sim?
I appreciate you help. I was finally able to get this installed, correctly, last night!If I remember correctly, the camera plugs in directly. There is an adapter for the radio. And another for the GPS. I bought another one for the LTE. They do provide their own antennas for GPS and LTE, but I didn't use those. I used the factory ones.
The half screen Android auto is actually a limitation of Android auto itself. Google hasn't ever updated it to make it larger. I'm using car Launcher Pro as my launcher. But I see no reason to have to use Android auto at all when it has all the Google Android stuff in it. You can run any app you want. And you could use your phone as a hotspot or actually get a SIM card and make it work without your phone ever.Anybody have thoughts on using it with Android auto mode vs tethered 'tablet' mode (w a dif launcher)?
A bit disappointed that Android Auto is stuck in half screen mode. It works great and so smooth, exactly what I wanted but underestimated how weird the big old empty black bars look when in Android Auto mode.
I like how it 'just works' though w wireless Android Auto... So a little hesitant to try and do a auto-tethering solution with something like Car Launcher Pro. How's the navigation and Spotify when using a custom launcher? I'd like some split screen goodness home screen that doesn't look tacky or give clunky tablet feels.
How did you change the background picture on the home page?
Make a 1080x1920 image then copy to USB. Open the File Manager>USB, open the image then tap the leftmost icon near below the screen for background wallpaper.How did you change the background picture on the home page?
Can you replace the speedometer/tachometer widget with something else? Sorry I’m trying to talk myself into this but am concerned about it lasting…Make a 1080x1920 image then copy to USB. Open the File Manager>USB, open the image then tap the leftmost icon near below the screen for background wallpaper.
No, not with their launcher. But you can use any Android launcher you want. There are a couple car ones and one that I use is Car Launcher Pro. It is highly customizable. I am not too concerned with it because Waze is mostly always on full screen.Can you replace the speedometer/tachometer widget with something else? Sorry I’m trying to talk myself into this but am concerned about it lasting…
Figured out the problem. The C1 connector into the HVAC module wasn’t connected all the way.I just installed the infotainment auto hvac kit, but I can’t seem to figure out the right settings in alfaobd to work with this. Should I leave the ICS enabled or disable it and enable the DCDS? Use only the Dual ATC setting and not the single ATC setting?
Mine is programmed to semi auto park.Anyone tried to press the TCS/ECS switch?
It will trigger the Max AC and turn off the AC instead the correct function.
The LED indicator sync with the OEM switch.
What protocol did you guys used?
Yes. I can push the button the steering wheel and Google Assistant comes on. I can even use the "OK Google" voice prompt.Does anyone know if voice commands work with the 13.6" screen?
