Adding Passive Entry: How-to
D-O-N-E! Thanks to MayhemMOORE for all the intel, Jimmy07 for the wiring, Tyler Potter for an awesome YouTube video and everyone else who contributed to this thread.72D7F635-ABAE-46AB-806D-6FD954B7DC50_1_201_a.jpegB7AE8DE5-2CB8-491C-9CCD-9EE36B0C1627_1_201_a.jpeg
How long did it take you? Pretty sure this will be my next project.
I started with the passenger side and it took about 4 hrs because I took my time, double checked connections and kept reviewing this thread and Tyler's video. Once that was done it made doing the driver's side much easier (about 1 1/2 hrs), then maybe 15 min to do the programming. I had done the Tailgate antenna on a previous day and that was the easiest part of the install. The most time consuming items were properly routing, re-taping and installing Jimmy07's wiring harness because I wanted to ensure I didn't bend or mess-up any pin locations. On a separate note I didn't have to disconnect the battery or cycle the ignition after the programming, I just waited about an hour went out to try it and it worked! Good luck.
When ordering cap for driver side ilustration shows one with cap with key. And which is driver side right or left?
If you are going to use the numbers below to order parts, double check them as things can change over time, so it's going to be up to you to verify you're getting the correct part when ordering. If you find a mistake please let me know so I can correct it.
5th Gen 1500 Handle and Cap Part Numbers
These should work on any of the 2019 and newer 5th gen 1500 trucks. Harnesses are going to be more specific based on your options, or you can just add the 2 wires and plugs to your existing stuff and save a good bit of money.
COLORBODY COLOR HANDLE, L & RBODY COLOR/CHROME HANDLE L & RHANDLE CAP, LEFTHANDLE CAP, RIGHT
Bright White6CV64GW7AD6CV361W7AD6CV50GW7AC6CV52GW7AB
Ivory White6CV64KGZAD6CV361WDAD6CV50JWDAC6CV52JWDAB
Diamond Black Crystal6CV64KXJAD6CV361XJAD6CV50KXJAC6CV52KXJAB
Maximum Steel Metallic6CV64KARAD6CV361ARAD6CV50KARAC6CV52KARAB
Granite Crystal Metallic6CV64LAUAD6CV361AUAD6CV50LAUAC6CV52LAUAB
Billet Silver Metallic6CV64JSCAD6CV361SCAD6CV50JSCAC6CV52JSCAB
Patriot Blue Pearl6CV64RPXAD6CV361PXAD6CV50RPXAC6CV52RPXAB
Blue Streak Pearl6CV64KCLAD6CV361CLAD6CV50KCLAC6CV52KCLAB
Flame Red6CV64PR4AD6CV361R4AD6CV50PR4AC6CV52PR4AB
Olive Green6CV64KFPAD6CV361FPAD6CV50KFPAC6CV52KFPAB
Replacement Clips for the 1500 door panels
Door Interior Trim Panel Retainer (Yellow): 6510747AA
Door Interior Trim Panel Retainer (White): 6510359AA
HD Part Numbers
Thank you to @01Time for providing the more comprehensive list below for the HD trucks than I had originally posted.
COLORBODY COLOR, FRONT LEFTBODY COLOR, FRONT RIGHTBODY COLOR, REAR LEFTBODY COLOR, REAR RIGHTBODY COLOR/CHROME, FRONT LEFTBODY COLOR/CHROME, FRONT RIGHTBODY COLOR/CHROME, REAR LEFTBODY COLOR/CHROME, REAR RIGHT
BILLET SILVER METALLIC1UJ81JSCAI1UJ86JSCAI1GH19JSCAF1GH18JSCAF6NV571SCAD6NV561SCAC6NV591SCAC6NV581SCAC
BLACK FOREST GREEN PEARL1UJ81KGZAI1UJ86KGZAI1GH19KGZAF1GH18KGZAF6NV571GZAD6NV561GZAC6NV591GZAC6NV581GZAC
BLUE STREAK PEARL1UJ81KCLAI1UJ86KCLAI1GH19KCLAF1GH18KCLAF6NV571CLAD6NV561CLAC6NV591CLAC6NV581CLAC
BRIGHT SILVER METALLIC1UJ81WS2AI1UJ86WS2AI1GH19WS2AF1GH18WS2AF6NV571S2AD6NV561S2AC6NV591S2AC6NV581S2AC
BRIGHT WHITE1UJ81GW7AI1UJ86GW7AI1GH19GW7AF1GH18GW7AF6NV571W7AD6NV561W7AC6NV591W7AC6NV581W7AC
BRILLIANT BLACK PEARL1UJ81AXRAI1UJ86AXRAI1GH19AXRAF1GH18AXRAF6NV571XRAD6NV561XRAC6NV591XRAC6NV581XRAC
DELMONICO RED1UJ81NRVAI1UJ86NRVAI1GH19NRVAF1GH18NRVAF6NV571RVAD6NV561RVAC6NV591RVAC6NV581RVAC
DIAMOND BLACK CRYSTAL PEARL1UJ81KXJAI1UJ86KXJAI1GH19KXJAF1GH18KXJAF6NV571XJAD6NV561XJAC6NV591XJAC6NV581XJAC
FLAME RED1UJ81PR4AI1UJ86PR4AI1GH19PR4AF1GH18PR4AF6NV571R4AD6NV561R4AC6NV591R4AC6NV581R4AC
GRANITE CRYSTAL METALLIC1UJ81LAUAI1UJ86LAUAI1GH19LAUAF1GH18LAUAF6NV571AUAD6NV561AUAC6NV591AUAC6NV581AUAC
MAXIMUM STEEL METALLIC1UJ81KARAI1UJ86KARAI1GH19KARAF1GH18KARAF6NV571ARAD6NV561ARAC6NV591ARAC6NV581ARAC
PATRIOT BLUE PEARL1UJ81RPXAI1UJ86RPXAI1GH19RPXAF1GH18RPXAF6NV571PXAD6NV561PXAC6NV591PXAC6NV581PXAC
PEARL WHITE1UJ81PWQAI1UJ86PWQAI1GH19PWQAF1GH18PWQAF6NV571WQAD6NV561WQAC6NV591WQAC6NV581WQAC
TRUE BLUE PEARL1UJ81KBUAI1UJ86KBUAI1GH19KBUAF1GH18KBUAF6NV571BUAD6NV561BUAC6NV591BUAC6NV581BUAC
WALNUT BROWN METALLIC1UJ81RUWAI1UJ86RUWAI1GH19RUWAF1GH18RUWAF6NV571UWAD6NV561UWAC6NV591UWAC6NV581UWAC
HYDRO BLUE METALLIC1GH19MBJAF1GH18MBJAF6NV571BJAD6NV561BJAC
OLIVE GREEN METALLIC1GH19KFPAF1GH18KFPAF6NV571FPAD6NV561FPAC
The following is a breakdown of the parts you will need to assemble your own 2-wire harnesses for the doors, as well as the rear antenna. All of the connectors and terminals can be found at Mouser or Digikey, except for the Yazaki stuff.
Rear Antenna Wiring Parts
22AWG wire (2 colors to make it easy)
Heat shrink tubing (recommended)
Braided wire sleeve (recommended)
Rear PE Antenna: 52112204AA or 56046957AA should work in this location
2019 & 2020 Rear Fascia Connector Terminals: TE Connectivity 1241380-1
2019 & 2020 Rear Fascia Connector Wire Seals: TE Connectivity 828904-1
2021 Rear Fascia Connector Terminals:
2021 Rear Fascia Connector Wire Seals:
2019+ Rear Antenna Connector Shell: TE Connectivity 1-1438608-5
2019+ Rear Antenna Connector Shell Terminals: TE Connectivity 1355717-1
2019+ Wire Seals for Antenna Terminals: TE Connectivity 963530-1
Door Handle Wiring Parts
18AWG wire (2 colors to make it easy)
Door Connector Terminals: Aptiv 10762775
Door Handle Connector Shell: Yazaki 7283-6079-30
Door Handle Connector Shell Terminals: Yazaki 7116-4720-02
Yazaki parts are hard to find without ordering minimum quantities. One option is to call SMD Inc, and see if they’ll send you free samples (2 connectors, 4 terminals).
Know part number for 2021 hydro pearl blue handles? And antenna?
How much total cost?
About $230 in parts from BAM Wholesale, $130 for Jimmy07’s wiring harnesses, $50 for the AlfaOBD software app, $25 for Security Bypass and $20 for OBDII Bluetooth/WiFi…total about $450.
I have alfa obd and the bypass and bluetooth already
Looks like the info for Hydro Blue parts is on pg.35, post #700 and Antenna info starts on pg.2, post #36.
Took a chance and ordered some parts. I can confirm these colors match the Hydro Blue Pearl paint.
Description:CAP. Door Handle. Left.
Part Number: 6CV50MBJAC
Quantity:1
Price:$ 7.56
Description:CAP. Door Handle. Right.
Part Number: 6CV52MBJAB
Quantity:1
Price:$ 7.56
Description:HANDLE. Exterior Door. Left, Right.
Part Number: 6CV64MBJAD
Quantity:2
Price:$ 54.99
Have a pic?
If anybody doesn’t want to spend the money for the entire door harnesses and rear facia harness, and doesn’t feel like building the add on harnesses with the parts, let me know and I can build them for you-
Hello there… can you ship it internationally? 🙏
Done, thank you to all that contributed
Been speed reading through both threads and just wanted to verify something.....
Since I have remote start I already have the required antennas except for the tailgate, right?
So I only have to buy the front D/S and P/S handles and a rear antenna (and wire that one up), reprogram with Alphaobd (with req security bypass) and I will be good to go.
Thanks
Thanks
You’ll need everything you mentioned. You’ll also need the wiring harnesses for the driver’s side, passenger side, and tailgate antenna. Your truck will not have the necessary wiring present for the passive entry. You can make your own harnesses if desired but many of us have purchased these harnesses through Jimmy07 here on the forum. Watch Tyler Potter’s video on YouTube of him adding passive entry to his TRX. That should help answer almost any additional questions you may have.
Thanks for the guidance JB!!!! I think I was confusing the wiring in the door (the button in the handle) with wiring up the antennas.....
Anyone with a granite crystal 2500 looking to do this? I bought all the parts and ended up selling my truck before I ever installed. Includes jimmy07 wiring, both factory painted handles, sgw bypass harness, and obdlink ex.
$425 for everything, brand new plus shipping. Contact me if interested.
Are the parts the same for a 1500?🤔
