WhiteKnight4x4
Did/are you guys ordering parts from your dealer or online?
Ordered mine from tascaparts online. Figured the dealer would just be more expensive.Did/are you guys ordering parts from your dealer or online?
I don’t believe global down works on 5th gens, and it is hit or miss on the 4th gens. Try something simple that is known for sure to work. If you have mirror turn signals, disable those. But, if AlfaOBD is connecting, and you can change that setting to yes or no, then it’s working.I must be missing something.. before I purchase all of the handles /caps and wire harnesses for passive entry. I want to make sure it's going to work before I get to a price of no return.
I purchased alfaobd, obdlink mx+, and the bypass cable from kaodtech. as a test, before spending more I tried to turn on global down and. nothing works. I even reset my settings. unplugged the battery for 5 mins and turned global back off and on.
I have a 2020 bighorn/longhorn with a 12-inch display
Lucky for you Patriot Blue is a standard color so you can get body colored handles with the proximity pads. People that have the special colors(Gator and Ceramic) are kinda SOL. I’m pretty sure I have some vinyl that will match Ceramic but if not I’ll just wrap the billet silver ones I already have matte blackI've tried to read through the thread, but I might have missed this. If that's the case, I apologise.
What is the total cost to add this passive entry? If it matters, I have a BTS BigHorn that has the matte black door handles... I assume I'll need to buy a full set of color matched handles.
Also, is it possible to change only the driver's door handle and have passive entry only at that door?
Maybe I missed the part number in the original post...need some door panel fasteners. Even the ones that didn't break dont fit in tight anymore at the bottom.
I thought I had posted the part numbers somewhere. If someone doesn’t chime in soon I will get them up later, I’ve got them on my computer.
You did. He’s wanting door pin fasteners
Not sure why you would want that. I’ve never had a vehicle with passive entry on all 4 doors, always the front doors only. Just set it to where when you unlock the front, everything unlocks.Amazing write up. Now, if only there were a way to add it to the rear doors....
I could see it coming in handy. For instance the first thing I do leaving work is put my bag in the rear floor before I get in. So have to walk to the front door and touch it, go back to the back and then open. Wouldn't be worth the additional cost to have rears though imo.Not sure why you would want that. I’ve never had a vehicle with passive entry on all 4 doors, always the front doors only. Just set it to where when you unlock the front, everything unlocks.
