I don't think the clamp trick proves there's any problem - it only proves that it's possible that the temperature coming out of the vents can be lower than it currently is. Whether that's because of the way it's designed, a software bug/flaw, or a mechanical flaw has not really been determined. And I don't think it will ever be determined unless someone can speak to the engineer(s) that designed the HVAC system for the Ram.There is a proven issue with the AC. It may work within "Ram spec" but it doesn't work as it should.
And when I say proven issue I mean proven by the drop in temp by the valve/clamp hack. If the AC was working correctly this hack wouldn't have the significant impact that it does.
I doubt RAM does anything about it though. It's all about $$$ and since their is no safety risk here they have no financial motivation to correct.
As long as the system is doing two things it is working: removing humidity from the air and lowering the air temperature across the coils. The temperature drop is what everyone is affecting with the clamp trick, but even without the clamp people are registering 45-55 degree temps out of the vents, which means there's a significant temperature drop across the unit. So there's really nothing for FCA to fix, because effectiveness and level of comfort is largely subjective. For me, the AC works fantastic. But I don't live in South Texas, and perhaps I would find it insufficient there - I can't say. I can't disagree with lots of people who don't find the AC system as effective as other vehicles, because that's entirely possible, but that still doesn't mean the system doesn't work as intended.
