2019REBEL
Here is the diagnostic and test procedure for DT air conditioning performance check:
Regards,
- Operate the HVAC system under the following conditions.
- Engine at 1,000 rpm at operating temperature
- Door and windows closed
- Transmission in PARK or NEUTRAL with parking brake set (depending on transmission application)
- A/C heater controls set to recirculation mode (MAX A/C), full cool, panel mode, high blower and with A/C compressor engaged. If the A/C compressor does not engage, see the A/C System Diagnosis table.
- Insert a thermometer in the driver side center panel air outlet and operate the A/C system until the thermometer temperature stabilizes.
NOTE: This procedure requires the technician to know what the temperature and relative humidity is at the time of the test. The temperature must be combined with the relative humidity to calculate the apparent ambient temperature ("feels like" temperature), when the temperatures are above 21°C (70°F). Use the current ambient temperature and the relative humidity in your location. This information can be obtained from multiple sources, such as the internet or local news media. - With the A/C clutch engaged, compare the air temperature at the center panel outlet and the A/C compressor discharge pressure (high side) to the A/C Performance Temperature and Pressure chart. The A/C clutch may cycle, depending upon the ambient temperature and humidity. If the A/C clutch cycles, use the readings obtained before the clutch disengaged (coldest temperature).
- Specifications: 70F ambient/45F output, 80F ambient/45F output, 90 ambient/55F output, 100F ambient/55F output, and 110F ambient/64F output.
Dusty
2019 Ram 1500 Silver Billet Laramie, Quad Cab, 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, 18 inch wheels. Build date: 17 April 2018. Now at 019719 miles.
Should be a number 5 on that. Vehicle outside with the sun beating down on it, not inside the garage where it is way cooler than outside.
