I used Noico sound mat off Amazon. They're all pretty similar and I've had good luck with it in other projects. I don't have any pictures unfortunately.
All the stuff really does is add mass to whatever material you stick it too. It's not going to really lower ambient noise... It's not really designed to. It does however change the resonant frequency of materials so that they don't rattle, buzz, or echo as much. A metal door panel is a great example. Knock on it with and without damping material and you'll immediately notice.
If you use it, I've found you don't have to go overboard. A couple sheets on a door panel does as much as plastering the entire thing most of time and weighs a lot less. If you removed the 6x9 you can reach into the door cavity and apply directly to the back of the outer metal door panels. The 6x9s themselves are mounted to a molded plastic barrier. I applied small pieces to the inside and outside of the mold. Again, this is simply to add mass and keep it from vibrating. I then applied pieces were I could to faces of the barrier and backside of the door panel itself. (take notice of the air bags... You don't want to cover those).
I test a lot of areas simply by knocking on panels. If it goes ding or dong, I add a bit of material to the back side and knock on it again. If it then goes thud or thump, I move on. Adding bunch more does very little.
If you want to lower road or wind nose, you need to use other materials such as MLV.
Hope this helps.
