34's vs 35's
Running Nitto Ridge Grappler 295/65r20 on 20x9 Fuel Vapor with 2" Rough Country leveling strut. It's more of 2.5 inch level once it settles. Love them so far. Drove a 2020 Trail Boss for a week and the 35" Nitto Ridge drives smoother and quieter
Had to settle for the Toyo's as custom offsets said the couldn't get the RG's after I paid for and waited two months. Luv the RG's though not unhappy with the Toyo's either Wm.
34" 275/65/R20 Cooper Discovery AT3 on Ram 1500 Laramie with ORG. Like the look. 53D920CF-5874-4A72-9876-3D2045FEF9C3.jpg
2” Readylift level
285/60/20 Toyo Open Country ATIII tires
20x9 +1 Fuel Rebel wheels
Originally I had the wheels in 20x10 with a -18 offset. I loved the look, but they rubbed quite a bit and I didn’t want to do any cutting. Im still more than happy with the current setup though. 11CA7212-B3E3-4BAE-B55E-A0D5B1FE26F5.jpeg
35's (295/65r20) 2" level
Sent from my SM-N976V using Tapatalk
THis looks great. any rubbing or trimming needed to run these?
2” Readylift level
Originally I had the wheels in 20x10 with a -18 offset. I loved the look, but they rubbed quite a bit and I didn’t want to do any cutting. Im still more than happy with the current setup though. View attachment 104350
I'm looking at the same rims and have a 2" motofab. Do you have any side shots? trying to decide how big of a tire to get to fill out the wheel well just a bit more and I'm getting tired of the stock tires looking like my truck skipped leg day.
Just recently installed 22x9 Vossens on Nitto Ridge Grapplers 35x12.5R22, already had spacers before. Love the new look, but did rub a little. Had to get rid of the little mini mud flap that comes on the Rebels. Also, I have the front Bilstein shocks to level it out. Overall, couldn't be happier minus the gas mileage hit lol. Speaking of, does anyone know if that affects the calculation itself since now the speedometer is off? How could I go about fixing that if there's a way to change the computer settings?
Finally finished with my level with new wheels and 34" tires. I now sit at 41.25" rear on both sides, 40" front. Couldn't be happier with my choices. Based on the modest budget i used im very happy.
Before tires
After
  • Like
Reactions: c3k
Any rubbing?
Zero rubbing full lock in all directions forward or reverse. Stock ORG suspension with OEM Laramie wheels.
285/70r18 Ridge Grapplers. Mathematically come out to 33.9”. Mounted I’m right at 33.0”.
6112s set at 2.6
1” block in the rear
35x12.5x22 Venom Power Hunter XT
Stock 22 factory rims
3.5 RL SST
.25 (1/4) wheel spacers
Slight rub reverse full lock
Pictures definitely don’t do justice!
Much taller in person!
@nivek1411 are you running the 3.21 or 3.94? I’m looking to do the same (2” level and 35x12.50s) but have concerns about the 3.21 not be able to push the 35s
Hey All
for some feedback on running 35s with the 3.21 rear. My mechanic raised concerns that it could “significantly impact” off the line and hi-way performance.
Currently running stock 285/45r22s on a 2021 Limited Black Night Edition with 5.7 Hemi w/Air Ride. Planning on 2” Revel/Daystar Leveling kit with new UCA’s.
I get I’ll be sacrificing some of the off the line performance but concerned the 3.21 might not be able to turn the 35s
