Idahoktm
I'm up for a good laugh. Explain.
Up for a good laugh eh. I don’t know how to put funny little videos on here, so probably won’t be too funny. I need to learn, because those are the funniest part of this forum. Anyway.I'm up for a good laugh. Explain.
I know people level trucks, that’s fine, but when they make fun of someone (me), “perhaps NOT a truck is what they need” when they wish to level their truck, I felt compelled to respond. Because if you really want to use your trucks full capability safely, you should not level it. He wasn’t using good judgement on who ”needs” a truck.
Starting with a leveled truck, with any load it starts to squat, and with heavy or max loads it will squat excessively and put much more weight on the rear axle, and less on the front axle, which adversary affects all kinds of important things like braking, steering, handling, head light angles etc. Some counter the squat with air bags that control the squatting, but with the expense of ride quality.
Trucks with an air suspension control the squat by adjusting the air to always have a level truck, eliminating the problems listed above. Stock trucks have a rake to be able to handle a heavy load, control the squat, while balancing ride quality.
Starting with a leveled truck with zero load is not good, if you really “need” a truck.
Didn’t miss that. I guess if he wants to ride on a rear suspension that’s feels hard as a rock, every time he “needs” his truck, well happy trails then.Obviously you read his signature but you still missed the part that said he had air bags.![]()
You said his truck would be less capable. It's not and it won't be with a leveling kit.Didn’t miss that. I guess if he wants to ride on a rear suspension that’s feels hard as a rock, every time he “needs” his truck, we’ll happy trails then.
Less capable of hauling safely and comfortably, yes.You said his truck would be less capable. It's not and it won't be with a leveling kit.
Let’s face it, you have a leveled castrated truck and don’t realize it.Let's face it, you got into a pissing match with another member. That's all this is.
3.21
The circle of life.
Other than a bed liner and cover, my truck will stay stock.The circle of life.
Level your truck, see how you like it. Ain’t gonna happen.
Well you know, in order to have a truck and use it, you must ride around at all times with maximum payload, perhaps a little over just because. You know, if you would just haul a dozen sheets of plywood or a pallet of light weight cinderblocks or a few dozen bags of mulch, well, you don't need a truck. That can go in your Prius just fine. (Hence they sell Rams with 3.21 gears)I'm up for a good laugh. Explain.
Oh yea,Well you know, in order to have a truck and use it, you must ride around at all times with maximum payload, perhaps a little over just because. You know, if you would just haul a dozen sheets of plywood or a pallet of light weight cinderblocks or a few dozen bags of mulch, well, you don't need a truck. That can go in your Prius just fine. (Hence they sell Rams with 3.21 gears)
So jack that back end up like your rolling downhill all day and load her up!
Oh HELL no!So I guess we’re done with gear ratios?
