2025 Ram 1500 Current Owners - Discussion, Feedback, and Problems
Has anyone tried to adjust the rear exhuast tips on a 2025? My drivers side is lower then the passenger side and I would like to move it up. I tried loosening the clamp behind the exhaust tip but it won't budge it's almost like it's welded.
I haven’t noticed a level difference, but I’ll look. I did notice that after only 600 miles there a plenty of surface rust on them. Disappointing.
I have not noticed any rust on my yet but they do get sooty much faster then the Hemi.
lol me too haha . Yes they adjust its a swivel clamp so easy to do i will do mine next oil change.You can put them in any position once you losen clamp.
ya, they're super easy to adjust. It's a 13mm socket to loosen the nut/clamp. I moved mine up so they're closer to the bumper. They were way too low.
Okay I will try again this weekend, probably just need to put a little more force into it to break it loose.
What did you consider “way too low?” Where are they now? Pics? Thanks
Has anyone discovered a fix for the headlights not coming on with key fob press?
My dealer wants to open a STAR case.
Nope - my dealer looked at it and said it was functioning as normal lol. My truck will not turn them on after the truck has been sitting off for 10 minutes or longer it seems. If I turn the truck off, then immediately get out and hit the unlock button, the approach lights seem to work. But then they don't after it's been off and locked for a bit. Which defeats the whole purpose.
Yeah, my dealer did a recalibration that didn’t help. I’ve gotta schedule the Star investigation.
Give us an update if they find anything out. I'd like mine to work all the time as well.
Of course! Oh, they did say that there were no software updates for my radio, so I must be on the latest version. I guess there’s still a chance Stellantis knows about it and it will get fixed without this process.
Got a weird feedback survey about my new Ram. Seemed to be very interested in opinions on power plants. Real EV intensive. For me it was easy. I'll take an i6 or hemi. You can keep your EV and hybrid in the showroom. Even had a question if I preferred an engine that sounded powerful, or one that felt powerful. Had a bit of feeling someone had been reading this forum.
Now I'm waiting for all my bank accounts to empty because it was phishing.
Removed “quietly”…. After many of us ordered it with the belief it was included as much as four wheels and doors. Then, after months of advertisements, they quietly added “late availability” to the website. And the hard button on the upper right side of the screen is missing, so they would have to use a soft button to add it, which is not likely.
Simply false advertising.
Confirmed that Active Park Assist (XPM) will not be available on MY25.
Anyone else experiencing significant wind noise when driving? Almost like the weatherstipping has gaps in it. It sounds as if my door is not shut all the way, but it certainly is.
No wind noise if all the windows are closed. But yesterday I had the rear slider opened, and it sounded like rain was hitting the truck. The skies were blue - no rain. It was the weirdest thing. It stopped when I closed the window. The sounds were NOT coming from the window itself. It was hard to pinpoint. Then I wondered if it's somehow part of the Active Noise Cancelling. I only mention it because who knows if it could be a cause of your wind noise?
did you have a toneau cover on? Mine sounds like that when the wind blows over the cover on the bed.
check your door window glass bottom seals. I had outside lowers that were bad on mine. wouldnt even wipe water off the glass when rolling the window down on one. they changed it and its much quieter now.
  • Back
