2023 disable seatbelt alarm?
FYI, 2024 with non digital dash. The 5 click procedure worked.
That's interesting. 2024 with digital dash, truck won't move, unless seatbelt is buckled.
Drove it twice about 5 miles each way with no belt to test it and it deleted the chime and drives.
Never saw that before.
Does it stop the message on the dash too, or just the ding?
I don't know, personally (I don't use that feature). I believe I remember someone saying that it just disables the chime, though.
not to mix apples and oranges but FYI, the non digital chime removal using the seat belt click procedure eliminates the chime and once in a while the seat belt sign will pop up in the center dash but it quickly goes away by itself. I can t remember if it only does it once or twice or more often.
It only does it once per drive.
I have a '23 and it does work but you must click then unclick more then three times! I'm pretty sure it was five times.
It does work just play around a little.
I am going to try this (5 clicks) on my 2024 Limited.
The 3 clicks DID NOT work, but I will report back.
shut the door, click belt before you do anything, wait till das lights go out before the 5 clicks. On other manufactures I ve done this with I found that you do not want to be too fast either. good luck!!
Tried it on my 2022 and it didn’t work. Just like Nav In Motion.
