Pi Esq.
@Fliphappy, what did you do to get "Special Scheduling Condition VII" on your build sheet, and/or did you even know about it?
Well, and I don't mean to make more work for you or anyone else, what is the distribution thereof relative to VINs?Guys, as of last week only ~1/3 of the trucks built had a special scheduling condition listed. I don't think it's the magic bullet that you think it is.
What I know for sure is that, per the 2022 Ram Tracker that you and @triple_B put together, the 16 highest VIN American build sheets each contain the "Special Scheduling Condition VII." That seems pretty meaningful.Guys, as of last week only ~1/3 of the trucks built had a special scheduling condition listed. I don't think it's the magic bullet that you think it is.
I see what you're looking for (i.e., a pattern). I just can't find one, though. Yes, most of the member builds have VII - but that could just be a function of the fact that they're sold orders. I have several dealer-listed build sheets in the upper ranges that have no special conditions. Same in the lower ranges. There's just nothing that I can find which suggests it makes any difference.Well, and I don't mean to make more work for you or anyone else, what is the distribution thereof relative to VINs?
That is, if 100 trucks have been built, and the 33 highest VINs are those with the special scheduling condition, then it could obviously mean something. It's just as possible for VIN 100201 to be ordered from someone with juice as it is for VIN 169001 to be ordered from someone with juice, so the fact that low VINs with special scheduling conditions have been built may not indicate anything.
Not saying you are wrong, simply saying that, without more information, I think the theory is still a theory without confirmation one way or the other.
Well, let's utilize the brethren we have. I say to you, the magnificent members of this fine forum, check your POC's to see if you have "Special Scheduling Condition VII" (or any other such condition), and, if so, report back if you have not yet received a build sheet.I see what you're looking for (i.e., a pattern). I just can't find one, though. Yes, most of the member builds have VII - but that could just be a function of the fact that they're sold orders. I have several dealer-listed build sheets in the upper ranges that have no special conditions. Same in the lower ranges. There's just nothing that I can find which suggests it makes any difference.
That won't be on any POC's. Best you'll find is the Build Priority.Well, let's utilize the brethren we have. I say to you, the magnificent members of this fine forum, check your POC's to see if you have "Special Scheduling Condition VII" (or any other such condition), and, if so, report back if you have not yet received a build sheet.
Ruining peoples' day is what gets me out of bed in the morningWell, crap. Way to rain on my parade there, @Eighty. I was having a whole "The Hangover" moment here and you ruined it.
My only condition is that it has been stuck in inspection for 14 days.Well, let's utilize the brethren we have. I say to you, the magnificent members of this fine forum, check your POC's to see if you have "Special Scheduling Condition VII" (or any other such condition), and, if so, report back if you have not yet received a build sheet.
If I‘m reading this correctly, a dealership who hasn’t used up all of its allocation could tag order to be prioritized? Another dealership who has used its allocation up (for example Mark Dodge), would not be able to get its order prioritized?I found this on a Charger web site;
-Special Scheduling Condition II
-Special Scheduling Condition VII
The first two are an internal code that is applied when the schedulers or another employee at Chrysler (Who has the authority) schedules an order when there isn't allocation or to give an order priority in scheduling. Chrysler distribution uses it to give allocation to a dealer for an order when the dealer has either used up all of it's allocation or otherwise does not have allocation for a certain order.
| Condition | Count | Total |
| II | 218 | 376 |
| III | 2253 | 2432 |
| VII | 2619 | 2761 |
| II, III | 94 | |
| II, VII | 57 | |
| III, VII | 78 | |
| II, III, VII | 7 |
Definitely not for me. Pretty much the only bright spot in this whole truck ordering ordeal.Ruining peoples' day is what gets me out of bed in the morning![]()
My Build Priority says 99What is the "Build Priority" on your POC? Mine says 01.
I also notice "Special Scheduling Condition VII" on my build sheet. I do not know if this factors in to anything?
I saw it was there, but don’t know what it means beyond the same google searches I’m sure others have done.@Fliphappy, what did you do to get "Special Scheduling Condition VII" on your build sheet, and/or did you even know about it?
