vincentw56
- Aug 5, 2020
Are you asking for an update? So, Jimmy and I have been working on this back and forth. The 19/20 will need a newer BCM. I have a 21 that we've been trying to replace my current 20 with, but we've not been very successful. We even met up to have Jimmy use his software to do a BCM replace. That still didn't work. This could be an issue with my BCM as it has been worked on by a few different people. Jimmy does know that a couple of 4th gen owners got it working in their trucks by making the newer BCM a slave. Basically, the BCM needs power and ground and a wire going to the mirror to send a simple signal at startup to tell the mirror to activate. This critical piece is all there is needed (that is why you need the newer BCM). As of right now, Jimmy is going to make the required wiring harness for me. He is just waiting on a connector. Once I get that from him, I will give it a try again. Since this has been done with the older trucks, I am confident that this will work (unless my BCM is totally screwed up).
