I plan to create a DIY air suspension link lift guide as soon as my truck arrives (hopefully later this month). My aim is ~2" lift to fit 35" Toyo RT's on the stock 20's.
I plan to do the same thing. Use a turnbuckle type rod to make adjustments at the sensors.
I just looked at the nitto ridge grappler 285/70R18 I think it’s the same tire as the BFG KO2 34/12.5/18 but not as wide so I Should haven’t scrubbing issue in the wheelwell correct?
Guys are running 305 55 20 on stock setups 33.25 x 12.25 without issue, I'd be really surprised if you had issues with the 34 12.50 on your stock 18s without a 2" level, with a 2" you'll be fine
I also started looking at the Nitto Ridge Grappler 285/70R18 which is almost as tall at the 34/12.5 but is 11.2" wide so I'm think those would be a better fit but I could be wrong
Looks good but dam that's pretty high, here I am with my 2" mopar lift thinking its already a mission hopping into the truck, I'm 5'7" asian dude and definitely needs some steps. Anyways here is my 2" mopar lift kit with RC front 2" coilspacers, definitely looks alot more leveled than before. For the DIYers heres the setup I used to removed and install the strut nut, without using the special tool. I honestly think Mopar should include a 2" coil spacer, it looks more proper than having that rake especially after lifting the truck, what you guys think? Installing the a Magnaflow muffler tomorrow, will update the forums on that later.
View attachment 6068View attachment 6069View attachment 6070View attachment 6071
Do you know the part number for the shocks? I’m putting a 4 inch Superlift kit from a 2018 on my truck and don’t like that came with my kit. Please let me know if you can get me the part number for the shocks
Method Racing wheels 20x9 +0.
Mopar 2" lift.
Falken AT3 34" tire (should have done 35").
24c7342a-aed2-46ef-bac3-1d46f2d580d6-jpeg.144986
Does the Mopar 2" lift raise the rear as well? From the pics I have seen, it appears to?
Now I have the Mopar oem 2” lift on mine but I’m still on the factory wheels / tires. I usually do not make good choices when it comes to that so I’m waiting to see what you gents are running.
Yes it does.. Mine has a 3-1/2" rake still after the Mopar Lift these pics don't look like it as there is some weight in the bed
20x9 Fuel Sledge (matte black face w/black gloss lip) wrapped in 275/60/20 Nitto Ridge Grapplers
Did you level it? I'm looking to do the same size rim, and tire. With that said, what offset did you go with?
