Ok, so just got back from the dealer as the Ready Lift pucks they used on my new truck ride like crap and I have a nice clunking sound that they claim they fixed.
I am thinking since the puck was not seated properly on my passenger side to start with, it f'd up the stock strut.
Anyway, I am thinking a set of RCs are going to be better than these bouncy pucks and there is no telling how long it will be before 5100s are available.
This has been so frustrating...have a brand new truck I think is gorgeous, but hate driving it cuz the ride is so bad.
Will be installing the RC struts this weekend.
Installed the RC struts yesterday. 2" exactly now sitting 1/4 " taller in the rear. Struts looked well made. Ride may be a little firmer if at all. I am happy with the outcome. 2019 quad cab 4x4.
How is the ride?Here are some pics of the RC struts. Any questions about them, fire away.
How'd the install go? Any issues? Looks great and glad you are pleased with the upgrade.Here are some pics of the RC struts. Any questions about them, fire away.
How is the ride?
How I did the install:
Remove tire, brake caliper and bracket, steering link, axle nut, lower strut bolt, UCA bolts, nuts on top of strut.
Swing UCA and steering knuckle out of the way. Pry down on LCA ( does not take much ) remove strut.
Insert new strut top end first start the nuts on the studs. Pry down on LCA and use another smaller pry bar
( if necessary ) to "saddle" the lower mount. Jacked up the LCA a couple of inches to attach the UCA.
I left the upper ball joint and sway bar link attached. I found torquing everything down once the tires where
on and truck on the ground was the least enjoyable part.
Please do not consider this a professionl guide on how to do this job it is only explanation of how I did it.
Thanks for the information. Did you have to get the truck aligned afterwards? If so, was there substantial adjustments that needed to be made? Thanks again, been looking for someone that has done this. I would only be gaining 1 inch since I have the Rebel, but one inch is one inch.
