2” Rough Country front leveling strut kit
SilverSurfer15
Looks like maybe they are competing with bilstien on this one. Although these aren’t adjustable
Bellpa
Pittsburgh, PA
Just did the online chat to ask about these and attached their response...
SilverSurfer15
If you look the reviews are based on that product for all makes And models, not just the 2019 ram. So that’s a little deceiving but I know they have been making these and coil overs for other models for awhile now.
Bellpa
Pittsburgh, PA
Makes sense then. I'm definitely interested in them, especially with the slow delay in Bilsteins for us.
Echance01
Phoenix, AZ
So is the “better” way to level a truck? Trying to understand why someone would go this route versus the spacers?
Bellpa
Pittsburgh, PA
Better struts(improved ride) with leveling height versus stock struts with leveling spacers.
SilverSurfer15
I would if I could do my own alignments. Someone should call rough country and ask for a free pair to advertise them on the forum here lol
Bellpa
Pittsburgh, PA
If I had the means to change them out, I definitely would call them. I'm sure they'll cut someone a generous break to promote these on here.
Maxram
My question is could you use this on the front combined with a 2" motofab spacer and new UCA's, stick 2" rear spacers on with the new RC V2 3-4.5" rear shocks to achieve a budget 4" level lift? Or would the diff have to be lowered?
SilverSurfer15
The diff has to be lowered.
SilverSurfer15
Kind of a Grey area, your “best” bet at the moment IMO is to get these, a 1” top spacer from the older trucks, and the readylift UCA.
*Assuming these are factory length struts*
A better route really is just buy the 6” kit, don’t use the preload spacer and run it around 5”. Or even swap in a 4” strut spacer from the previous gen trucks. And use a 2” rear spacer.
spaightlabs
I've seen about a metric crap load of posts complaining about the quality of Rough Country lift kits. Any reason to believe their struts would be any better?
R
Rob5589
Guest
My thoughts exactly. Jump on any Jeep forum and you'll learn all about the (mostly) garbage RC puts out. Poorly valved shocks, sagging springs, poor welds, etc. I wouldn't run these for free.
