Vinnie.
you can look at your door sticker and do the slightest amount of math to get your truck weight.
GVWR - Payload = Truck Weight.
Where exactly on the door sticker? I think you're speaking of the gross vehicle weight...My truck weighs 5883lbs based off door sticker and that lines up with what I've seen at the scales at the dump.
Theres no chance there's a truck that weighs 4800lbs.
your stickers tell you the GVWR (white sticker) and the payload (yellow sticker "combined weight of occupants and cargo should never exceed (payload value))... subtract the payload from the GVWR and you have your curb weight.Where exactly on the door sticker? I think you're speaking of the gross vehicle weight...
Your formula is a little off. It's GVRW - Tire & Load Capacity = Curb weight. My truck is 4,998 pounds.your stickers tell you the GVWR (white sticker) and the payload (yellow sticker "combined weight of occupants and cargo should never exceed (payload value))... subtract the payload from the GVWR and you have your curb weight.
Mine on the scale is 5860 but I do have some stuff under my backseat in storage. My zero to 60 best is 5.7These trucks can be almost 6,000lbs. Your truck weighs much more than 4,8000lbs. A Dodge charger weighs 4800lbs almost.
My trucks curb weight is 4,998 pounds. I wouldn't exactly say that's "much more" than 4,800.These trucks can be almost 6,000lbs. Your truck weighs much more than 4,8000lbs. A Dodge charger weighs 4800lbs almost.
tire and load capactiy.... what exactly do you think payload is referring to? the value on your yellow sticker is your payload value.Your formula is a little off. It's GVRW - Tire & Load Capacity = Curb weight. My truck is 4,998 pounds.
I read your first post incorrectly, I apologize.tire and load capactiy.... what exactly do you think payload is referring to? the value on your yellow sticker is your payload value.
GVWR - Payload= curb weight.
this is my first truck so maybe i'm way off...
@devildodge care to educate me?
It's all fine. Some of us can own up to our mistakes like men, unlike a few others. (You know who you are. )i accept your apology hahaha no worries
You are already educated @Vinnie. Spot on.tire and load capactiy.... what exactly do you think payload is referring to? the value on your yellow sticker is your payload value.
Post your door sticker.My trucks curb weight is 4,998 pounds. I wouldn't exactly say that's "much more" than 4,800.
