rsonedecker
- Dec 12, 2018
North Packages around here get the 1" lift. The original package announcement indicated a 1" lift.If the Raised Ride Height is not on the build sheet, the truck did not get the 1". For instance, there is the North package that had nearly all of the off-road but not extra 1". There were also a couple of regional sales packages that had everything but the lift and a different wheel/tire combo. What the OP needs is his original order print out fron his dealer. I suspect they may have done a build without it.
These should be the part numbers on your truck (non-air-suspension) - check your back shock and spring:
Rear Spring - 68262686AB or 68262684AB
Rear Shock - 68262592AC
Also there will be a green sticker on one of the shocks that says "Shock Absorber - Lifted"
