Electrical
- Dec 16, 2018
It's as if they ran out of budget after designing that tailgate. This is no longer a premium brand.
If the tiny 24 gallon fuel tank wasn't enough to send you running away, I just learned it doesn't have adaptive cruise control. Instead, they give you something called "Following Distance Indicator"... which tells you how far the car in front is, but that's all. You can even set the gap. But... WHY?? It doesn't do anything. Are they trying to trick people into thinking they have ACC??
And the analog tach and speedo. Carryover from a 1987 Pontiac Gran Am??
I also just learned there is no gear indicator on this truck. The truck tells you you're in "D"... but not which gear.
Man I really don't get this truck.
Check out the "Augmented Reality" camera view. Did they layoff developers mid-project?? Look at the vertical lines cutting off the view to the left and right.
