How to: Add Adaptive Cruise Control, Lane assist, FCW & Auto Hi-beam to Ram 1500
Tried again and I cleared everything but C10D0. I need to disable EPB In-Plant Mode for this? I just keep getting “Failed. Service Not Supported In Active Diagnostic Session.
Do read system status and make sure both the ESC and EPB plant mode disabled procedure is run before doing it. Restart alfa app. Make sure parking brake is off by toggling the switch. Keep ignition on and then keep foot off brake. Make sure the parking brake doesn’t auto engage. Once you are sure its off, run the service procedures-> assembly check. You should hear the brakes go and off and then clear codes. You should be good then
This worked! Thanks! Took it for a spin and everything is working and codes are gone.
If vin showed up after you did system read it worked. If not disconnect battery for 30mins and retry. I had to do that once when i initially started. But after i was able to get vin to all ? after vin reset i followed post #812. Between each step i had to cycle ignition twice, run reset ecu twice, close alfa app and restart it in tablet.
I ended up taking it to the dealer and even they just let me know they can't get the VIN to populate in the ABS module. So now they are putting in a ticket to see what they find out. With my luck, the ABS module I received is bad.
Finally got my windshield replacement done last week but ran into issues with uconnect top buttons. So basically i bought a used DASM and installed it after getting the windshield done but my uconnect top button for lanesense wouldn’t do anything at all.
IMPORTANT: I used cda6 and turns out you can “enter and exit plant mode” in that. Hopefully Alfa can add that support option for RAM cruise control. Once i did that all the mismatch codes and service required messages went away and i could enable ACC. Now im guessing since its a used DASM it retained the previous calibration which is why it let me get away with that. Also in cda6 it was showing fields for auto calibration enabled so im guessing even if i didn’t do anything and drove around it will eventually calibrate itself. Some people in other forums mentioned that as well after windshield replacement and driving around DASM fixed itself.
Now my next issue was lane sense button on uc5. Initially the screen i got didn’t have the buttons from factory and while reading through the digital cluster swap TRX forum they mentioned that buttons can be swapped over and thats what i did from a donor uc5 unit that had broken screen. Turns out it’s not true as me and [mention]MannyN [/mention] had found out the hard way. There is something different in the main board as well and that needs to be swapped over as well from the donor unit. So i ended up getting another screen which came with buttons and now everything is working with all used parts.
I do have dealer appointment scheduled to do the DASM alignment still but so far everything seems fine.
Thank you [mention]vincentw56 [/mention] [mention]Jimmy07 [/mention] [mention]MannyN [/mention] and others for all the information.
UPDATE: I went to the dealer and they actually broke the DASM lol. After i left the dealer and was going home all the ACC FCW LKA AHB warnings came on. When i went back to them they made me wait another hour only to come back and tell they couldn’t work on it. I spoke to the tech and they used a actual bubble level and guesswork to make the DASM sit straight
I asked the tech to show me the service procedure and as [mention]Jimmy07 [/mention] mentioned it needs to sit at -1 degrees. The document process he showed me on screen had a digital level like device but its not the same because it can read angle in negative degrees.
FIX: I do have cda6 so i decided to tackle it myself because the dealer said it will be a couple of weeks to get that “inclinometer” that reads negative degrees.
I decided to give it a shot myself. After messing around for a bit this is what i did:
The codes in DASM:
I didn’t picture this part but basically you need to take off the rearview mirror and covers around DASM.
Get yourself one of this on Amazon. The model number is in picture. Around 30$
There is a E torx screw on right side of DASM bracket. I used E6 socket and turned it clockwise/anticlockwise until i got the 91.0 degrees on the screen. Make sure the digital level is in 180 degrees mode and not 90.
The dealer had it set at 85 degrees no wonder it was freaking out
You will need to hold this digital level flat on DASM.
DO NOT APPLY PRESSURE. JUST HOLD IT GENTLY AGAINST DASM.
I measure the DASM near the right bracket, center, near the connector. I made sure all 3 spots on the back heatsink read the same 91 degrees.
After this reinstall rear view mirror and all the plastic covers.
Go into CDA6:
Start this process. You will see the cluster display FRONT RADAR SENSOR ALIGN MODE.
Disconnect from OBD and drive around. SPEED must be between 41mph and 78mph. I went on highway for 15mins.
You can check the status by randomly tapping the ACC button after a few mins and you will see the ALIGN MODE message displayed. That means its still processing.
Once it finished it will automatically display ACC FCW LKA enabled and all the warnings go away. I drove around for a bit and tested all the systems to make sure it works.
If all went well there should be no codes and you can clear everything.
Given that cda6 can do this and it also let me ENTER/EXIT plant mode, its ideal for everything we need.
Idk if AlfaOBD developer is on this forum but if he is then can [mention]Jimmy07 [/mention] [mention]vincentw56 [/mention] or someone tag them or send this to them? Since their app is built around cda6 they should be able to add this to Alfa and help others needing it.
The dealer wanted to charge me another 360$ for 2 shop hours because he has to physically align the DASM with the digital tool.
[mention]Jimmy07 [/mention] if you know the digital level they use to read negative degrees can you link it here so someone who needs it can buy it. The one i used is a reputable one but just doesn’t do negative angles.
I wasn’t sure if -1 degree would equal to 89 or 91 degrees on this device but after a bit of messing around for hours 91 did the trick and that is correct because it has to be pointing up a bit to ignore the hood and front of truck plus have additional distance to scan ahead.
The codes in DASM:
Go into CDA6:
I wasn’t sure is -1 degree would equal to 89 or 91 degrees on this device but after a bit of messing around for hours 91 did the trick and that is correct because it has to be pointing up a bit to ignore the hood and front of truck plus have additional distance to scan ahead.
The developer isn't on here, but you can contact him through the AlfaOBD website.
How’s it going everyone,
I have a question that hopefully someone can chime in and know the answer.
I have a buddy that has a 2025 Level 0 RHO which comes with most of the options that came on the 2019+ advanced safety group (blind spot, ACC, auto high beams, FCW, etc… but one thing he’s missing is the rain sensing wipers.
Since he has the rest of the stuff, would he be able to, eventually when alfaOBD comes out with 2025+ support, add the rain sensor, add the stock and enable the feature when it’s available with AlfaOBD and that’s it? Or does he need to purchase another DASM and other parts?
This is exactly what comes on the Level 0 which might help. Thanks in advance.
The 2025s are much different. DASM isn't really the same thing anymore. The rain sensor on the 2024 and below is separate, so it should be the same on the 2025+. It's mounted in the windshield. In theory, just adding it and making changes using AlfaOBD should work.
Hmm I see online the sensor is from 2019-2024 so it for sure might be different on the 25’s
Yes, at this time, we don't know what needs to be done to make it work. But the biggest hurdle by far is the programmer.
Hey all, selling the blind spot modules if anyone is interested in adding that feature. Ended up grabbing the already built in taillights from a junkyard. Shoot me a message.
I have a 22 limited with FCW. Did the replacement for ABS and HCU. Cleared all the codes, as instructed in this thread, now it shows "Auto Emergency Braking (AEB)/ACC unavailable Service required" after using acc for a while. It will disappear if I cycle the ignition. But alfaOBD doesn't show any codes.
That is good information to have, I did not realize that.
So right now I have 3 yellow lights on the dash and messages on the dash. No codes are showing in Alpha.
The lights are
-Service Forward Collision Warning (FCW) Light
-Adaptive Cruise Control (ACC) Fault Warning Light
-in the bottom right corner there is a Star with a truck and OFF under it. Which I can't find in the manual but I think it's related to pedestrian emergency braking?
I also have messages saying
-Auto Emergency Braking (AEB) Unavailable Service Required.
- When I select standard Cruise Control it pops up Canceled immediately.
I have also went into the display settings and tried to turn on Automatic Emergency Braking >Warning + Braking and it selects and then goes back to off.
Reading above post makes me thinking if I got the wrong modules. I got new:
HCU: 68415320AA
ABS: 68728724AA (description says it replaces 68436462AK)
Ok, it’s looking like you did receive non-adaptive cruise abs and hcu modules. Based on the posts from the member in the pics below, that is what his abs part shows in alfaobd also. So, essentially, you did the same thing as installing the switch and just enabling the adaptive cruise settings, which yields no faults, but all the errors on the cluster.
View attachment 191327View attachment 191328
Confirmed that the alfaobd shows the same part number as 68728724AA
Can anyone help me decide if I got the wrong modules?
Thanks!
New to Ram. I have a 2025 that I bought used. Can I enable lane centering? I have everything else (ACC, Lane Keep Assist, FCW) and I really thought it had the lane centering.
Truck is about perfect, just missing that one thing.
No, you can't do anything on the 2025+. It's been mentioned above.
HCU: 68415320AA
Thanks!
UPDATE: Finally got it working thanks to this post:
I successfully completed my upgrades yesterday. I took the time to consolidate the steps to help anyone who is trying to piece together different threads for adding the adaptive cruise control. Amazing work done by a lot of people to build this thread and share their process.
  • Parts Used for My 2023 Limited w/ Forward Collision Avoidance w/ Emergency Braking
    • Hydraulic Control Unit – Mopar Part 68415320AA $439.27 from FactoryMoparDirect.Com
    • Anti-lock Brake System Module– Mopar Part 68436462AA $297.00 from FactoryMoparDirect.Com
  • ABS>DT 2019+> ECS In Plant Mode> Disable
  • ABS>DT 2019+ > EPB In Plant Mode> Disable
  • ABS > DT 2019> Service Procedures > Assembly Check
When this was all done, I only had one remaining error which was the EPB error. This cleared when I engaged and released the parking brake and cycled the ignition one time.
I hope this helps. I tried to consolidate the steps into one place. I think this process will work the same if you buy a used part.
I also attached a version to make it easier to print if anyone is like me an likes to have a checklist to follow.
You can follow the PDF in above post to Run Longitudinal acceleration sensor calibration, which requires special steps on my 22 RAM. Also, I think i missed Service Procedures > Assembly Check. After that, everything works!
The following is to be used as a guide on how to install ACC, FCW, Lane Assist, Auto High Beam headlights and rain-sensitive wipers in your 5th Gen Ram 1500, also known as the Advanced Safety Group. I’ve also included a guide at the end of this document on how to install blind spot monitoring. Obviously, I cannot guarantee this will work on your truck, but I am confident it will. I was able to install all these features on my 2019 Ram Lonestar which originally came with an 8.4" Non-Nav Unit with Dual Climate control. I believe this can be activated on any 5th Gen, but I’m literally the first person to have done this (that I am aware of) so it’s possible there are unknown variables that will prevent activation. This install is for those that have experience with AlphaOBD and assumes you are familiar with basic terms and procedures. It is not advised to do this as your first project, but you are free to do as you want. I believe this to be a mostly complete guide, but I wrote this from memory after 8 months working on this project so some things might have slipped through the cracks. Big thanks to all those involved along the way.
The purpose of this thread is not to debate "if it's worth it" or to discourage others from spending their money how they want. Everyone has different opinions on this. I took this project on as a personal challenge to see if it was even possible and with a larger goal in mind than just these stock features.
Additional download link: ACC Guide Full (3).pdf
Wondering if you ever added the sales codes to your truck when you added the acc? Was told it won't work with out the sales code added and that doesn't seem to be true. Thanks for the write up.
No one has added the sales code because it cannot be done. Ram will never do it. And you don't need it at all. None of us needed it. The only issue you will run into is if you take the truck in and they reset the BCM configuration. And all you need to do then is add the settings back in through AlfaOBD.
I picked up my used abs/hcu module from the salvage company, It’s supposed to have the acc with stop go but I’m worried they gave me one that doesn’t.
It has part number 68432417AC on it and the one eBay listing that matches says it doesn’t have the acc feature. But I can’t find anything else matching the part number, hoping one of yall whos better with mopar part numbers can help me out.
I got feeling they just sent a random one smh 😑, I was gonna install everything this week but guess not
Update: I decided to read the system I’d on the module by unplugging the current abs module and plugging this one in. The vin attached to this module is 1C6RREFT6KN745814.
I looked up the window sticker (see attached photo) and don’t see the advanced safety group so unless someone that knows better says otherwise I’m gonna assume this doesn’t have stop go 😡.
I looked up the window sticker (see attached photo) and don’t see the advanced safety group so unless someone that knows better says otherwise I’m gonna assume this doesn’t have stop go .
View attachment 210996View attachment 210997
It wouldn't have that as it is a Big Horn and they didn't have that as an option that year.
