HOW TO: Add 360 Surround View Camera System
Vincentw57, can you please tell, or anyone, how did you go from your side mirror to the inside of the truck. There was no detail. Please help
There is a door harness that you can run it through. If you need more details, look into the thread about adding passive entry.
Remember that you need different tailgate handle as camera is bigger. Also connector is different.
If I understand you, the existing backup camera on my truck handle doesn't work with the 360 surround view camera system? Is that correct?
If you're in need of a new cvpm, I've got one that I'll make you a deal on! I bought it brand new from the mopar store and then ended up buying a used one so I didn't have to calibrate the new one!
Do you think a blue screen camera unavailable can be a defective cvpm? I’ve had the blue screen for about 2 months checked all cables and camera with no luck. Cameras are the only issue I have.
Thoughts?
Thanks
That's correct. That's why it's listed in the parts list and explained in the first post.
My 2020 Limited already has 360 camera, but I'm looking to do the UC5 upgrade from infotainment.. If i buy the UC5 CVPM Part Number 56029968AF would I be able to do the calibration via AlfaOBD and MX+? I'm basically looking to see if i can do the UC5 upgrade without any dealer intervention.
Yes, you can. You can also do the UC5 upgrade much cheaper if you do it all yourself.
