PR40.1 Update File?
Does this update (or any update) provide functionality for Wireless Car Play? Have 2021 RAM.
Thanks
Nope. Wireless CarPlay was not integrated until Uconnect 5 on ‘22’s and newer.
However, there are aftermarket USB dongles that are capable of providing Wireless CarPlay with UConnect 4. I use a Magic Box 2.0 and am pleased with its Wireless CarPlay capabilities.
Hi everyone just wanted to post my success in updating straight from 34.2 to 40.1 using the file St-na linked here. It estimated 35 minutes but really took 25. It did stay on 19% for a while which had me really nervous but it eventually kept going.
I'll outline my steps as a recap.
1. I quick formatted a 4gb drive to Fat32. Note that if you use a really large drive it may have exFat only and the truck will not recognize it. This happened to me with a 128gb drive i tried first.
2. Unzip contents to root of that drive.
3. Turn truck to Run. I did not start the engine.
4. Insert drive into front USB port. Ensure your phone isn't plugged in running AA or carplay.
5. Accept the update and watch it load. I sat and screwed around on my phone for 25 minutes and was all set
Thanks everyone for your help.
I dont understand, I did everything that all others did here. My radio will not update. im stuck on 34.41, gps reliability is at none, several usbs.
Had the truck at the dealership since friday. They said they "reflashed" the radio with updated software. That was a lie its still at 34.31. Charged me 445$ to tell me that they updated it.
I had GPS for about an hour and now im getting "device not supported" again.
Im so frusterated with this and Ram.
Ram Care has not helped one bit.
try calling uconnect via the help button in truck. then get your money back from dealer
motorola ma1 about $60
Did you try an incremental update to 39.xx first?
Hello all, a little late to the show. I am at 33.3. Does anyone have LR 34? I have found 39.7, 39.9 and 40.1. assume I need to update in that order. any assistance is greatly appreciated.
Thank you
Does anyone have the file(s) to manually update uconnect, similar to what was provided with PR39.9?
Secondarily, one of the fixes/updates listed is "Android Auto Enhancements". Can anyone confirm what that is? Hoping for full screen AA, but I haven't seen anyone post that they have this version installed.
I'm out of warranty and the dealer wants $180 to do the update. I will do it if I know if AA goes to full screen.
All those files has to be in folder like this on flash drive plus flash drive has to be formated in FAT32, no other stuff on it.
i only get to 19% i tryed it 5 times and get error code i used 2 diffrent sticks to any ideas
What version you have? Sometimes you need to do update older first. Don't jump to latest, do what's next available after your version then next one until you reach last.
Sent from my SM-S928U using Tapatalk
