Correct, all I am able to see is 39.9. Please someone post a link to 40.1I see on google drive latest 39.9, where is PR40.1?
12" UC4 MY19-21 Firmware - Google Drive
drive.google.com
drive.google.com
drive.google.com
Read the PDF from post #13.Hoping you guys can help.....
I have a 2021 2500 big horn, I upgraded from the 5 inch non nav to 12 inch nav.
It's currently on software 18.5, tried to update to 40.1 but failed with error code 20.
I'm guessing it failed due to such a large gap in versions. Plan to try 28 then go up from there. Anyone else try this? Any input is welcome
Although the PDF wasn't much help my assumption was correct.Read the PDF from post #13.
Good to hear, glad it didn't brick the unit.Not sure but it worked, thanks for taking the time to respond
Good to hear, glad it didn't brick the unit!
Yes I was able to get it to 40.1. Had to do incremental updates to get there.Good to hear, glad it didn't brick the unit.
I feel like my HK system has less bass.Any noticable difference with 40.1?
Hold the bottom left and right icons on the touch screen for a few seconds and you'll enter a menu where you can check radio softwareHow do I check to see what software mine is currently running?
From 18.6 yes, the system is a lot more snappy and more stable.Any noticable difference with 40.1?
No, Canadia has different versionsDo these files work for Canadian trucks?
